Hatch Release Button Doesn't Release
PTS
Delaware
2024 Mach-E
My 2024 Mach-e Select does not have a power lift gate. Occasionally, when I try to push the hatch release button, it doesn't release. The tail lights blink when the button is pressed, but hatch does not open. I have the key fob in pocket. This does not happen with the doors, only the rear hatch.
Is anyone else experiencing this issue? It is a security setting? Again, it is intermittent, but I cannot determine a pattern.
flapjake314
NYC
Mach-E Select AWD
i've experienced this and it's usually solved by unlocking the doors first, not sure why it happens though it's rare for me
Ford Motor Company
Official Ford Account
Hi there! Will you send us a message with your VIN and your local Ford dealer? We’d like to investigate this release button concern on our end. Thanks!
PTS
Delaware
2024 Mach-E
I was told not to send my VIN on a public forum. Do you have a private account?
johnnycombo
Pennsylvania
I’ve given my vin to the Ford account and gotten my problem solved. Your vin is in more danger in a Walmart parking lot than here.
Send them a direct message. Click on their name (Ford Motor Company) then click on direct message. That is the official Ford USA presence on this forum.
Anvil Jr.
SF Bay Area
2023 Ford Mach e Select
I have the same exact issue. What I do to pop it instead of fumbling with the key fob is to open one of the rear doors and immediately shut it. This then allows me to open the hatch. Super annoying. Please post the solution if you find one.
IMDIDOC
Alex
Buffalo NY
2021 Mach-E FE
Optometrist
Sometimes I must open one of the doors before the hatch.
Ford Motor Company
Good afternoon. Go ahead and send us a private message with your VIN and the name and location of your Ford dealer, and we’ll look into this concern you're experiencing. Thank you!
SalsabyJake
Jake
2023 Mach E Premium
Musician
I'm guessing here, but I think when the car is in deep sleep mode, it sometimes takes a press of the button to wake it up. I've seen this on door buttons too. Did you try just pressing it a second time? Theoretically, walking up to the car with PAAK or the fob will wake it up, but it is not always a sure thing....
Anvil Jr.
SF Bay Area
Yep, I did press it several times. When I tried it yesterday it worked fine. It hasn’t done that in quite a while. Very odd. We will see what today holds.
mdwinther35
Matt
SE Michigan
2023 Mach E Select AWD
I've had this issue, seems to come and go. I've gone through multiple weeks where it doesn't work properly, then it will for several weeks. Currently it's working, hoping it stays that way. Maybe it has something to do with OTA's, but haven't kept notes to correlate behavior to any specific update.
