Help power window switch cover broken
Starscrean
Terrence
Uniondale
2023 Mach e
Tech
Before I go balls to the wall and start pulling stuff
Anyone have a clue how to remove this broken plastic
Ford Mustang Mach-E Help power window switch cover broken IMG_1849
Absolutely. Follow these steps:
1) Call your dealer and make an appointment.
2) Show up, and have them replace switch under warranty.
Starscrean
Starscrean
Terrence
Uniondale
2023 Mach e
Tech
Wonderfull if they replace this without blaming me for doing something to it. Thank you. I’ll make a call tomorrow , i didn’t think it would be covered.
If it broke in normal use, and you're within 3 years / 36,000 miles, it will be covered. If you hit it with a hammer, it won't.
GatorGrowl
United States
2023 Mustang Mach-e Premium ER RWD
To answer your original question, that is a module. You can’t replace the individual switch cover.
The good news is it’s not horribly expensive, around $30. Part number is LV4Z-14529-AA
Starscrean
Starscrean
Terrence
Uniondale
2023 Mach e
Tech
Thank you GatorGrowl. You understood the question.
Other than the obvious “Call the dealer”. Which I really didn't want to do. This other option is exactly what I wanted to know. Thanks.
