Help with Setting up PAAK (Solution found)
Ghost Ryder
LA
Tesla MYP, 22 GTPE
I had PAAK set up since I got the car in March 22. It has worked well enough. However as of last week, it just disappeared.
I went on vacation for 2 weeks, so the car sat at home. It went into deep sleep. I'm not sure if it's related. When I got home from vacay, PAAK did not respond, so I used the door code and back up password. I didn't think anything of it as this happens with PAAK every so often. But when PAAK failed for a couple of days, I decided to trouble shoot it. One of the first thing I did was log out of the Ford Pass app. When I logged back in, PAAK was gone. It's like I've never set it up. There was a link on the APP that ask me to set up PAAK. However when I tried, it would fail to Download a digital Key. Tried multiple times, always the same results, "Key Download failed." I tried everything I could think of. I even reset the PAAK from the MME and erased blue tooth from the phone as well as delete all phone connections. Nothing helped.
Has anyone ran into this problem with "key download failed." I have a iphone 13pro.
I just found a solution to the "Key download failed." In my particular situaton.
You have to set your phone (not the car) to 24 hour mode. Then the download would go through.
Hope this helps others with this problem.
Yes. I had this problem, and reached out to a contact at Ford. Here is the solution that worked for me.
1) On your phone, delete cache and clear data from the app.
2) Delete app.
3) Reboot phone.
4) Reinstall FordPass.
5) Ensure location settings are set to always allow (I think current version reminds you of this).
6) Ensure background data is enabled.
7) Retry PaaK setup.
Ghost Ryder
LA
Tesla MYP, 22 GTPE
2) Delete app.
3) Reboot phone.
How do you delete cache and clear data from the ford app? I've gone into settings, but there's no option to clear cache or data. This is on iOS 16.2.
Don't know, don't have Apple. On Android, you go into the PHONE'S settings, pick apps, pick FordPass, pick Storage and Cache. It's not in the app's settigns.
Uninstalling an app on iOS or Android will delete the app and its storage cache and locally persisted settings.
Ghost Ryder
LA
Tesla MYP, 22 GTPE
In that case, then RickMache's solution did not work for me as I 've deleted the app and reinstalled it multiple times and still have the failed to download error.
Yeah I was gonna say, since the vehicle already thought it was paired with PaaK I'd add an additional first step:
Delete the PaaK pairing from within the vehicle.
And on Android, I'd also remove the PaaK Bluetooth pairing before reloading and logging back in to FordPass. Not sure if you need to do that on iOS as I have no experience there.
Ghost Ryder
LA
Tesla MYP, 22 GTPE
Yeah, I tried all that. Did a PAAK reset with the MME that removed all PAAK settings including the backup password. Deleted all bluetooth pairing.
Nothing is working. At this point, I'm going to see if I can get it to work on another phone. Its really frustrating.
Shaggyrn
Wick
Oklahoma
2021 Mach E, 2012 Ford Fusion, 2007 Exp. Sport Tr
I also had this problem about a year ago. I did all the above recommendations also and it never would get a key. The module that runs the pakk actually wasn't working (Ben could see on FDRS) I had to take it in to dealer to have it looked at. From what I was told the power pin on the module itself was not making good contact and kept the module from powering on. They stated fixed it by working on the plug to the module. It now works great. (knocking on wood). If you know someone with FDRS have them plug in and see if your Paak module is showing up is what I would try.
ShaggySS
Scott
Roseville, CA
2022 Mach-E Premium RWD
IT Nerd
Keep in mind your will have two bluetooth connections. One for PAAK and one for Sync. You must delete the correct one in my car "24227 MACH E" is my PAAK. I am assuming you also deleted the phone from the settings\profile menu?
Where is it failing when you are trying to set it up again?
Ghost Ryder
LA
Tesla MYP, 22 GTPE
I've deleted both.
It fails when trying to download the key. the exact message is "Key Download failed."
you have to 'reset PAAK' in MME, un-install and delete everything and both BT pairings in both phone and MME, and start completely from scratch. Make sure you have a good wifi connection from MME to some network before you start.
ShaggySS
Scott
Roseville, CA
IT Nerd
I've deleted both.
can you hold the volume down and track next button (opposite of sync reset) scroll down to connectivity and let me know what you see here. Curious about TCU status.
Ghost Ryder
LA
Tesla MYP, 22 GTPE
Yup, did all that. Only thing I didn't do is a Master Reset, but I reset everything else. I'm really at a lost on what to do. Even called Ford and tried their suggestions and nothing works.
ShaggySS
Scott
Roseville, CA
IT Nerd
Don't make the same mistake I did by going to master reset too early. That is a lot of work to set back up.
