HOT (OVERHEAT) PHONE using wireless charging in Mach-E
67 Stang Convertible
Rich
Georgia, USA
Physician
Guys, my (Iphone 10) can only last on the wireless charger for about 40-45 min before the phone gets so hot that the phone shuts down and hence so does Apple Car Play. I was just watching a review of the Rivian R1T and he had the same issue; although he says it craps out after 30 min.
Am I alone in this? Is it just the Apple Phones or certain Apple models; are the Androids doing the same?
It does not affect me much as I generally have a charged phone everyday; but the biggest issue is when taking a trip and using Apple Car Play (Waze or Apple Maps). I do love the wireless option but will begrudgingly have to use a wired option on trips.
There's a TSB for this: TSB 22-2265 - Wireless Accessory Charger Inoperative/Poor Performance With Magsafe Charging iPhones
Basically your dealer can update the WACM module. The phone will not get as hot after the update. It still gets warm but not enough to shut down post update.
Not having the main display on CarPlay also helps (streaming video takes way more power than operating in the background).
DR.J56
Texas
My iPhone 12 mini does this also. I plug into the usb instead. The wireless charger doesn’t add much charge at all. It’s really useless.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Inductive charging is grossly inefficient and creates a ton of waste heat. Bluetooth connections create heat. Using GPS creates a lot of heat. Streaming music creates heat. So wireless carplay with navigation or streaming will overheat your phone. You don’t notice how terrible inductive charging is anywhere else because you’re not using GPS at the same time. Solution is to plug the phone in and charge without the resistance of induction, or use a magsafe charger if your phone is capable of such. The wireless charging pad sounds cool, but it’s slow and inefficient at best.
Yup.
Had phones with wireless charging at one point. What a waste of electricity that is, as compared to plugging in. But, it did prolong the life of the charging port, before USB-C at least.
brancky3
Brandon
Greenville, SC
'21 GT
While you're mostly right, you're also wrong because I've driven other cars that don't have this problem...
scoopman
Bay Area
I just put this in instead, problem solved, no TSB or dealer visit required. CarPlay works great for 9 hours with my iPhone on this Anker MagSafe charger.
Ford Mustang Mach-E HOT (OVERHEAT) PHONE using wireless charging in Mach-E 4A1BCE81-B7B8-43D2-91B2-6190506BC2FD
slimothyjames
Ontario, Canada
Mach E Premium AWD
I don't use the wireless charger if that phone is what is connected to CarPlay.
The rubber mat in the MME plus the thickness of whatever case you're using is a pretty big gap/thickness of material, which is super inefficient and causes a ton of heat.
One of our phones has a thick case and we have to take it out of the case to use the wireless charger or else it gets super hot.
ShaggySS
Scott
Roseville, CA
2022 Mach-E Premium RWD
IT Nerd
I just dropped mine off for the TSB. My issue was that the phone would only charge for a minute or two and then stop. I don't use carplay daily so I don't experience any heat.
iPhone 12 Pro with mag safe case.
The TSB should fix the issue of it stopping charging. But it will still get hot.
Murse-In-Airy
Rod
Chaumont, NY
Mach-E ER AWD
Nurse
Maybe didn’t have wireless CarPlay? So you weren’t using the GPS and streaming? or had a lower power inductive charger?
ShaggySS
Scott
Roseville, CA
IT Nerd
Sadly my car build was one week after the TSB so they didn't update. They gave me a two page print out of DTC codes and want it back in a few weeks.... ?
What's your build date? They've extended the TSB date a couple of times.
ShaggySS
Scott
Roseville, CA
IT Nerd
26 Apr '22 build date.
The latest TSB I could find says on or before 4/17/2022. Sounds like they keep releasing TSB for this so maybe the next one will include my build.
Tom L
Tom
Chippewa Falls, WI
2018 Honda Clarity
I was intrigued by this question nd some responses so I did a little experiment with wireless charging my iPhone SE 22 with 69% charge, medium thick case and 82 miles of driving on today's errands. I finished at 82% charge with no overheating, not even warm.
