How Do I Know If The Battery Is Pre Conditioning?
Wow that is a lot of detail. I am big into the software stuff, but under the hood of a modern car not so much.
Yeah. I have always been the mechanical type. The Magna designed system in the FFE had a passive valve in the system and the Mach-E ended up with a mechanical one. Now I hear Ford has realized the mechanical valve isn't needed and will be removed at some future model refresh.
Yes - no battery warm up when you precondition...the preconditioning time is not enough to warm up that size battery anyway as far as I know).
Also if for some reason you dont plug it in overnight but have precondition to run when not plugged in, expect the precondition to run on east coast time (may be different from local time). There is a setting for time zone which defaults to east coast (detroit unless it shows differently for you in Canada) and cant be changed yet. And the ford pass message in that case will be something like SRS (scheduled Remote Start) triggered etc.
Very interesting and actually explains some strange behavior I have observed recently.
Thanks! :)
MorsRedigo
MorsRedigo
Sean
Winnipeg
2021 Mustang Mache
Thanks everyone for the help and the discussion! I am happy we can all share our experiences and learn from each other.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Thanks! :)
You guys are fast out there you unplug and bam you are in a different time zone ;). I see how it may confuse and appear it does not work if not plugged in. It did just a few hours earlier and not noted.
