MellowJohnny
- Christian
- Nov 16, 2021
- YYZ
- 2022 Mach-E Premium AWD
- Solution Architect
This is interesting - I set a departure time for 7:30 this morning but the car was stone cold. It was plugged in, but precondition time was outside of my "preferred" charging time, if that matters. I also have "Allow start when vehicle is unplugged" set to true in FordPass. The only other time I've tried it was 4:45 am (during the "charging" window) and it worked fine. So this was disappointing.<snip>
For what its worth, I have found Departure Times are more reliably set in the car. Tap the car icon, tap Settings, and select Charge. You can edit your charge times and depature times there.
I will check to see if the same settings were transferred from FordPass to the car...wife has it at work right now
