- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Situation: You're coming out of the store and you want to put some items in your frunk. You use the frunk button in FordPass to open the frunk. You hear the release motor pull, but then you notice it only pulled once instead of the usual twice. The hood is open slightly, but you can't lift it open. So you open your door and try pulling the manual release. But you notice there's strangely no resistance when you pull the lever, and nothing happens. Hood still won't open. You push down and slam the hood as hard as you dare, but it still won't latch closed. You try pulling up on the hood forcefully, but you can't get it to release. You try the frunk button again, but don't hear any motor noises this time. The hood is stuck between open and closed and there's nothing you can do to fix it! Ugh! You may try to drive away, but are quickly met with a "Frunk Ajar" warning message that can't be cleared and the car hyper dings at you NONSTOP as long as you're moving. You don't dare drive faster than 35 MPH because you're worried about the hood blowing open, which will instantly block your view and break the windshield. So you're faced with the decision to drive home very slowly, or call a tow truck. Not a good day, and it means you suddenly don't have a working car anymore.
Unfortunately what has happened is the electric hood release actuator motor has gotten stuck in the retracted position. And due to the design of the 2x pull hood latch, the mechanism is stuck in a state that can neither be opened nor closed. There is no manual override or way you can get it unstuck externally. This exact situation has happened to a few people on the forum. And it's quite a difficult situation to fix since there is no easy way to get the hood open. In the past, dealers have resorted to trying to remove the entire front bumper, cutting holes, or cutting the latch to get it open. But there is a better way.
After this happened to me recently, I was able develop new non-destructive entry method. In a nutshell, you need to unbolt the hood striker through the tiny opening, open the hood, and partially remove the frunk tub to gain access to the stuck mechanism. I'm sharing this so the dealer doesn't destroy your car if it happens to you.
To avoid this situation, do not use the electronic frunk release. I used mine a couple times per week and it failed in about 20 months. Manual cable release is safe.
Replacement Part
You will start with the hood stuck open about 3/4" and will work have to work through the narrow gap. Sitting on the ground in front of the car works best so the opening is at eye level.
Procedure
Replacement Part
- LJ8Z-16700-C - Hood Latch Release Actuator
- 10mm extra long ratcheting box end wrench with flexible heads (must be at least 10" long)
- 12 inch or longer pry bar or flat screwdriver
- Narrow flashlight
- 10 mm socket + ratchet
- T-30 Torx bit
- Plastic pry tool
- 2" wide masking tape
Procedure
- If you're worried about scratching, cover rough finished tools with electrical tape. Also put wide masking tape on the lip of the hood and the top of the bumper panel so the tools don't scratch as they're slid in and out.
- Using the flashlight, locate the two 10 mm acorn nuts holding the striker on the underside of the hood. Use the pry bar to lift up the gasket so you can see:
- Insert the ratcheting wrench, making sure it's flipped the correct way to loosen instead of tighten the nuts. Use the pry bar to help guide the wrench up onto the nuts. You'll need to hold the wrench up on the nut with the pry bar while turning:
- Loosen the nut with the wrench. When it gets loose enough the wrench won't turn it anymore, remove the wrench and use the pry bar to manually spin the nut the rest of the way off. This takes some patience as you'll have to do 1/6th a turn at a time. When the nut finally drops off, try to push it back so it falls into the frunk tub. Repeat on the other side.
- At this point you can open the hood, but the striker will still be stuck in the latch:
- Next step is to remove all the frunk panels (center, left, right). Pull up by each clip to remove them.
- Use the pry tool to remove the four plastic covers at the bottom of the frunk tub to expose the bolts.
- Remove all the 10 mm frunk tub bolts. There are 6x in bottom and 2x at the top rear.
- Pry up the knurled plastic trim piece surrounding the striker and remove 2x T-30 screws underneath. You won't be able to fully remove this piece, but you can get the screws out under it.
- The frunk tub should now be loose. Lift up on the driver's side and wedge something like a wood block under the lip to hold it up:
- This next part is hard to describe, but take a look at the mechanism in the next photo. You need to push the top of the pivot arm forwards with the pry bar to release the cable. This mechanism is on the inside of aluminum radiator support rail where you can't see it, so you have to feel for it. You want to feel for a vertical paddle shaped object, guide the pry bar onto it, and push forwards.
- Push firmly on the pivot arm until you feel it move, don't hammer. It will push forward about an inch or two. The cable to the latch should now be slack.
- At this point, have a helper hold the striker and manually pull the hood release from inside the car. The striker should pop out and be free!
- If you have the replacement actuator part, you can now fully remove the frunk tub to replace it (remove light and release button first). If you don't have the part, you can put everything back together as-is. The manual cable release will still work normally if the actuator stays forward. If you're not replacing it today, I recommend unplugging the release motor so it doesn't get stuck again.
- Lubricate the hood latch if desired.
- After the actuator is replaced (which you should do so the emergency release works in case of 12V battery failure), put everything back together.
- You may need to adjust the left-right position of the striker if the hood panel gaps are not equal on both sides with the hood closed. Loosen the bolts and reposition if necessary.
