How to open Body Control Module Fuse Box
volarium
Phoenix, AZ
2022 Ford Mustang Mach-E GT Grabber Blue
I feel like a complete idiot, but I can’t figure out how to open the fuse box under the glove box. The owners manual literally just has a photo of it with an arrow, and I couldn’t find any YouTube videos with that particular fuse box. Do I just pull? Do I have to remove the panel that’s just above it? If anyone can point me to instructions or a video, would be much appreciated.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Looks clear as mod.
I would guess you peal it off from the top.
Ford Mustang Mach-E How to open Body Control Module Fuse Box IMG_3392
AliRafiee
Ali
Seattle WA
Software Eng.
The 24 manual has this. But I guess that not a picture of the fuse box.
Ford Mustang Mach-E How to open Body Control Module Fuse Box IMG_3393
noway
Norway
2021 Mach-E First Edition
Software developer
There is two plastic trim-fasteners that has to be removed ro get the cover off. The type with a center piece that has to be removed first
volarium
volarium
Phoenix, AZ
Thanks much everyone, got it opened, and removed the fuse, which allowed me to finally get Paak working for the first time! I don’t even necessarily want to use it instead of bringing the key, it was just driving me crazy that it wouldn’t work.
theganyo
2021 Mustang Mach-E Premium AWD
Don't feel bad, I couldn't figure it out either. I was pulling so hard I was concerned I would damage it, so I stopped trying. I still don't understand exactly how to do it... even the comments here aren't clear to me. :/
volarium
volarium
Phoenix, AZ
There are two panels. The one on the bottom is where the fuses are. Just above that, there is another panel under the glove box. If you look up, you’ll see two circles with a square in the middle. You get a small flat screwdriver and pry the little square and then pull on it. Then, you use the screwdriver to pry the circle and then pull on that. Once those two tabs come out, then the top panel should just drop down (might have to pull gently). Then, for the lower panel, you just put your hand behind it and pull gently. There are tabs holding that in, but they will come loose with pressure.
Hope this helps!
alexgorod
Alex
DBA
Hope this helps!
I hope that you still remember :)
Is it below the glove box, or it needs to be removed first to get access to the fuse box?
Ford Mustang Mach-E How to open Body Control Module Fuse Box 20260201_103537
Is the white square plastic thing the one that covers the fuses and needs to be removed?
No. Look up at the FRONT of that top panel. You will see 2 fasteners. Using a screwdriver, pull the middle section of each out, then the panel comes down.
The white thing is the footwell light. Do not attempt to remove that. On the edge of the privacy panel that is farthest from the firewall (closest to the glove box hinge) there are two plastic reusable rivets. Pull the center pin out of the plastic rivets and remove them. The edge of the panel closest to the glove box hinge can then be lowered away from the bottom of the dash and then you can slide its feet from their mooring points. 😁🐩
