MadMatt
Montreal
2024 Mach E Select AWD
Thanks ?. I didn't know it had to be plugged in. I figured 10 mins on battery wouldn't hurt. Luckily it rarely gets below freezing here. I'll plug it in if it's gonna be real cold.
when you use the scheduled departure feature in the app and are plugged in,
Open the app 30min or so before the time to leave you’ll see at the top “precondition battery”. Closer to the departure time it will also show it’s doing the cabin as well.
so at least the app lets you know when it’s happening.
It warms the battery just by being on idling ?
Electric cars don’t idle. The electric motor(s) only run when required to. There is no excess heat when just sitting there. Pushing the “start” button is rather misleading.
DumpsterJ
Justin
Grandy , NC USA
2021 Mach-E Premium AWD X
I didn't mean idling in the literal sense. I guess sitting there idle would have been a better way to phrase that.
MadMatt
Montreal
This is what I was trying to say, at the top it tells you if it’s only doing the cabin or the battery as well.
I had a scheduled departure for 12:30. today. By 11:53 is was already working on the battery.
for context my mme is parked in my garage kept at around 8c
it’s currently -12c outdoors though.
I also keep it locked to 80% and plug in everytime I get home. (I do a 100% around once every 2 weeks.
Ford Mustang Mach-E How to Remotely Precondition Battery IMG_2580
AEGinMD
Art
Washington, D.C.
2022 Mustang Mach e Ice Blue Silver (Nov 2022)
Happily retired government bureaucrat
Here's an recent example of the benefit of preconditioning on charging level & speed: On a recent below-freezing morning without setting a departure time, my car charged overnight only to 140 miles of range @ 90%. (first time I ever saw it that low). Tried it again two days later with a departure time set, and it charged to 203 by the departure time.
Doobster6
Len
Exton, PA
2024 Mach-E Premium extended battery, Vapor Blue
Retired manufacturing executive
Since Ford still doesn't have a dang battery precondition button...I had a hunch. For those of you with the remote climate control settings showing up in FordPass, there is a way to use the remote controls to heat the battery. The car must be plugged in and parked in below-freezing conditions; otherwise the A/C will run instead.
Once you start climate control with the fan button, tap on the climate settings box and set the cabin temp to LO. Make sure defrost is off. You can turn on heated seat/wheel if desired. When you accept the setting, the temp shown may change from LO to 59ºF, just ignore that.
The LO setting is sort of special because it disables cabin heat regardless of temperature. With no cabin heat demand, the powertrain strategy will allow battery heating instead if the battery is cold (also works while driving).
The only negative is the fan will blow raw outside air into the cabin. But if the car is already bone cold, it doesn't really matter.
In my test, the battery temperature was raised +8ºC in the 15-minute remote climate period. Since you get two climate activations, you could then do a subsequent remote climate and change the temp to 72ºF or whatever to actually warm up the cabin the second time.
If you do not have the remote climate controls in FordPass, you can also do this by changing your remote start settings to "last setting" instead of AUTO on the main screen, and shutting off HVAC before you leave the car. Then start remote climate. Not nearly as convenient, but it works if really necessary.
It is my understanding that pre-setting a departure time using the Ford Pass App does the same thing. I believe it will both warm up the cabin and heat the battery if scheduled enough in advance. And yes, the car must be plugged in to level 2 charger. I‘ve been doing this over the past week when our temps have been in the 20’s, pre-scheduling 60-90 minutes in advance, which I just guessed would be enough time.
MME Farmer
Mn
2026 nautilus, 2021 GTPE, 2026 F350, 2017 F150, 05 trailb, 04 PT, 94 Dod 2500
Farmer
It is a good work around. It heats the battery or the cabin it does not do both effectively at the same time. Old last winters app you could set it for last used and turn the HVAC off before exiting. Remote start, extend and run again.
A twist is to go out to the car, starting it, turning the HVAC off, turning auto off to off, lock the car and walk away. You can leave it on for an hours if it has the juice to get them to 20C. You can hear to recirc pump and when it stops. Just leave it running and shut down HVAC before exiting. Gas vehicle do it at the corner store why not us! Consumes peanuts and worth it in some temps if you can.
At -20C I would start thinking about warming them up before driving it if not plug in and it has sat for awhile. I would go out start it and go back inside. Shut down HVAC is the key. The ones that think 10 Kw ($1.50) is something to save do not live where breaking down means you could freeze to death.
It comes on lately automatically plugged to L2, runs for 20 minutes or so, the recirc pump working (most likely not to 20C). This is the auto conditioning that started last winter. Last year it said preparing to drive this year preparing cabin and battery for departure ?‍♂. Nope not either. Why not keep it simple conditioning the vehicle. It is doing it all by itself now; it is growing up.
Best of the season to all.
Curious about this topic and stumbled onto this thread. Yesterday I had stops in town and I had warmed the battery before I left home, but it had cooled down during an appointment. I tried as you said to leave the car on, shut off HVAC and such, but I still had a bunch of gray bars which tells me the battery didn't warm. I don't have the climate settings as Lee mentioned. My next plan was to try turning on the climate remotely with the HVAC off I think as Lee had mentioned.
Shayne
Northern Ontario Canada
2021 MME4x Prem
Did you hear the recic pump kick on before you left? As soon as the cabin heat is shut down you should hear it click in. Remote starting with no heat and it started with no heat is about the same.
<SNIP>
<SNIP>
A lot of us don’t have the climate settings. My 2024 is fully up to date via FDRS and it doesn’t have the climate settings. Just waiting for Ford’s back-end team to get it sorted. ?‍♂?
Shayne
2021 MME4x Prem
I don't think I have it job 1? There is is a setting in the sync remote start since the beginning that is something like last used. Set it to that and turn HVAC off before leaving? Not sure if that will work have not tried it but I know shutting the HVAC to off is the ticket to it switching to heating the pack. Watched the cabin heat up on OBD while the battery stayed at -11 C shut the HVAC off and watched it heat the battery to 20C +/- then shut down.
What I am not sure of is after that 20 30 minutes it took to heat the pack up and then it shuts down it will cool. I did not sit there in the cold long enough to see if it will kick on again and at what battery temp that happens. If you are running in for 1/2 an hour shutting hvac off should do something.
-20C here this morning we will see if it wakes up for its departure schedule. No remote starts just departure schedules and block heaters. But remote start extended (30 minutes) if it starts with hvac off should heat the batteries. Should hear the recirc pump walking up and get into a cold cabin. I know I can start it, hear it and walk away.
MME Farmer
Mn
Farmer
I don't recall hearing anything. I just left it turned on and shut off the HVAC but it didn't seem to heat the battery (going by gray bars).
Shayne
2021 MME4x Prem
Grey bars is not really the way to ensure it is heating the battery. I had a recent BCM OTA so tried it again yesterday and it works as before. As soon as you turn off the hvac you will hear the recirc pump start. Turning the hvac off remotely or manually is the same thing. It is a high pitched hum the same thing you hear for departure schedules at the start (preconditioning). This is the sound of the fluid being pumped through the pack. If the heater is heating the cabin it is most likely heating the pack as it is one in the same. You can watch it on a obd2 app. They should rethink preconditioning a bit so there is not so many hoops.
I have no grey bars on my trim but yesterdays start after it ran a departure schedule it was 1.4 mi/kw but it went up to 1.8. Where has my range gone is my battery broke? ;)
MME Farmer
Mn
Farmer
That's interesting, I'll have to pay more attention and see what happens. I do know that this is some poor engineering in that the one heater is way too small to serve two purposes. There should have been a dedicated heater for the cabin and one for the battery. I know if it gets down to -15-20F this rig is staying in the garage. As I mentioned before I think they did their winter testing in Arizona! At the least Ford should offer a larger replacement heater, but space probably doesn't allow.
the golden eel
Twin Cities, MN
MME 2022 Premium AWD Extended Range
I tried something similar 2 years ago by having the car navigate to a nearby DCFC while it sat in the parking lot at work. It technically works, but you've got to walk out to a cold car to start the process.
Here is the post... https://www.macheforum.com/site/threads/battery-preconditioning-some-measured-data.25598/post-593607
And here is the text copied from what I did...
"So I just finished up with this. Got in the car and turned off E-Heat, the fan, heated seats, and heated steering wheel. Used the Ford map to navigate to a DCFC 11 miles away. As soon as I pressed "GO" on the nav I heard a whirring in the car. I assume that was the battery warming itself. At this point I left the car with my phone (key) and it beeped twice at me as I started to walk away. Which makes sense since it was on and I was walking away with the key - just sharing details.
SOC was 85% with a GOM of 194 miles.
After 30 minutes I checked and the SOC was 81% with a GOM of 210 miles.
So I guess this work around is better than nothing for the really cold days, but I would prefer a simple button on the app, instead of having to walk to the car. "
Shayne
2021 MME4x Prem
Charge goes down and range goes up as batteries heat up makes sense. There is no need to turn the seat and wheel heat off it is the resistance heater that does hvac and batteries. You can come back to a warm seat and wheel.
