Ev Blau
- Ev
- Apr 30, 2023
- Asheville
- Ford Mustang Mach-e
- Retired
Good morning. I wish I could parse your statement “It’s soooo easy to simply connect the battery tender to the pigtail in the MMe.” Huh? Please explain to the uninitiated who want to learn from you. Thanks.Replacing the 12v on your own is a PITA.
In my view, this alone makes it different than the above references to a 12v in an ICE vehicle (it is not an EZPZ task when it dies). My thoughts:
1. ICE vehicles don‘t lock you out when the 12v goes bad.
2. You cannot easily swap out the MMe 12v. To remove the 12v, you have to remove way more than just remove the FRUNK trim panels, and will likely need dealer intervention.
3. Getting stranded in the MMe is more arduous than an ICE vehicle (jump the FRUNK, remove panels, etc.)
In my view, if you do not frequently drive your MMe (especially when it’s cold), it’s worth considering a battery tender. The MMe will not intervene to charge the 12v until its charge drops to an unacceptably low level (again my opinion) and repeated cycles of this are problematic for the 12v. I find it easier and more efficient than the suggestions of others (use an inefficient 120v charger to prolong the charging process, etc). It’s soooo easy to simply connect the battery tender to the pigtail in the MMe.
I just prophylacticly replaced my 12v after 3 years because it outweighed the risk of getting stuck in the cold again at an inopportune time (like most folks, if I’m out in the cold it’s only because I’ve got things to do…places to be). I also acknowledge I’m more risk averse about getting inconvenienced in the cold than most people.
