Luke
- Luciano
- Feb 19, 2021
- MA, USA
- Mustang Mach e, Taurus
- Computer Engineer
Sorry you are having a bad experience.
You mentioned you are using a 30A circuit to connect the mobile charger, correct? When I plug mine I see it draws close to 7kW (about 29A). If your circuit is limited at 30A it will be very easy to trip the circuit breaker. You might need to check with an electrician to increase that. Or use a different charger that allows to control the amount of electricity drawn from the wall plug. Unfortunately neither the MME or the included mobile charger allows for adjustment on max power.
