Ford Motor Company
Official Ford Account
Hi Mustang Mach-E owners,
With the holiday season around the corner, initiatives like the Ford Power Promise are helping customers have peace of mind with home charging, so that they can travel with confidence.
As some states witness below freezing temperatures, here are some tips from our Ford experts on how you can best prepare your electric vehicle to maximize range and performance during cold weather.
Ford Mustang Mach-E Ice & Easy: Winter Driving Tips from Ford 1212241
1. Park your electric vehicle in a garage, if possible: Garage storage helps to ensure that harsh weather conditions outside do not affect your vehicle and maintaining a warmer storage temperature than outdoors will aid in vehicle and battery performance.  And with zero tailpipe emissions, you can safely warm up the vehicle's cabin while garaged.
2. Remove all snow from the vehicle before driving: This is important to reduce weight and reduce air resistance when driving, but it's also important for visibility and your own safety. Several of Ford's driver assistance technologies make use of sensors and cameras that must be free of snow to function properly.
Did You Know? Ford’s patented Vapor Injection Heat Pump (VIHP) is designed to help improve heat transfer capability and reduce power consumption. Being equipped with the heat pump aids in optimizing energy consumption, especially in colder weather.
The heat pump in the 2024 electric F-150 Lightning pickup and upcoming 2025 electric Mustang Mach-E SUV works automatically so the driver doesn’t have to do anything special to utilize the benefits, apart from driving with more confidence during winter. Fan noise may be heard while the heat pump is running, which is normal.
3. Plug in your electric vehicle when parked for extended periods of time: Keeping the vehicle plugged while parked for extended periods of time, such as while you’re away on a trip or even while parked at home overnight works to maintain battery health and helps to prevent range loss. 
When the vehicle is plugged in, the vehicle’s battery temperature is kept above freezing temperatures to help optimize battery performance; this occurs regardless of whether or not the vehicle is actively charging while plugged in.
Did you Know? If you’re heading toward a DC fast charging station (using your vehicle’s navigation or Google Maps via Android Auto), your battery will now start to warm up automatically within 20 miles of your destination.  
4. Set daily Departure Times to precondition both the vehicle’s battery and cabin while plugged-in: If you have a regular reoccurring driving schedule, such as a daily commute, preconditioning the battery using Ford’s Departure Times feature allows it to warm to optimum temperature before use, positively affecting range and power.
For Ford electric vehicle owners, Departure Times can be scheduled using the vehicle’s SYNC touchscreen under charge settings or from the comfort of your couch using the FordPass app’s Departure Times feature under Energy/Schedule. 
“The big advantage of owning an electric Mustang Mach-E is the comfort of getting into a warm car every day. Pre-conditioning via the app until my departure time is a complete game-changer. A quick snow and ice brush and we are good to go." – Ellen Anne Bye and her husband, Peter Arne Lislien (pictured) are both proud owners of their electric Mustang Mach-E SUVs. They live in Sigdal, Norway, where temperatures sometimes drop to -40 degrees Fahrenheit.
Never Get Into a Cold Car Again: Preconditioning Your Vehicle
One of the most frequent questions new electric vehicle owners have been around how they can precondition their vehicle.
Preconditioning helps your vehicle's battery perform at its best by adjusting the battery temperature to an ideal state before you start driving or charging. This not only increases charging efficiency but also helps to ensure consistent vehicle performance.
Just follow these easy steps to get it done without even getting into the driver's seat.
  • First, open the FordPass app and switch over to the "Energy" tab, where you can find your schedule preferences.
    • Ford Mustang Mach-E Ice & Easy: Winter Driving Tips from Ford 1212243
  • Here is where you'll be able to adjust your departure settings.
  • When plugged in, your vehicle cabin and battery will be preconditioned by your set time for every day that you have selected. If you're not plugged in, you can select the "Prepare Cabin Off Plug" option. This option allows the Departure Times feature to prepare your cabin comfort settings. Preconditioning only occurs when the vehicle is plugged in.
    • Ford Mustang Mach-E Ice & Easy: Winter Driving Tips from Ford 1212244
  • Within the "Departure Time" menu, you'll see options to edit time, dates, and cabin comfort levels.
    • Ford Mustang Mach-E Ice & Easy: Winter Driving Tips from Ford 1212245
  • Select the time you want your vehicle to be ready by.
    • Ford Mustang Mach-E Ice & Easy: Winter Driving Tips from Ford 1212246
  • Then you can choose which days of the week you want the preconditioning to take place. This is especially convenient when you have a set schedule or a regular commute to work.
    • Ford Mustang Mach-E Ice & Easy: Winter Driving Tips from Ford 1212247
  • Finally, you can choose the level of cabin comfort – Cool, Medium or Warm - you want to experience when you get into your vehicle.
    • Ford Mustang Mach-E Ice & Easy: Winter Driving Tips from Ford 1212248
  • And that's it! Press the 'save' button in the top right corner and your electric vehicle’s cabin will be ready to your liking with an optimized battery for your set times and days of the week.
5. Reduce energy consumption used by the vehicle climate control system: If equipped, use the heated seats and heated steering wheel as primary heat and lower the cabin temperature setting to reduce energy consumed by using climate control.  For DC fast charging (also known as Level 3) sessions minimize cabin heating while plugged in and charging.
“During the winter months or if I plan to go skiing, I precondition my F-150 Lightning in the garage while plugged in. Regenerative braking helps me a great deal while driving downhill from the mountains. I was at Mount Blue Sky recently and loved getting range back on my drive downhill,” said Les and Marlene Strickland, Mustang Mach-E and F-150 Lightning owners and residents of Broomfield, Colorado.
Did you Know? You can adjust your cabin temperature, defrost, heated seats and heated steering wheel options from your phone using FordPass. From the FordPass-vehicle tab, simply select remote climate (fan icon) and scroll down to "Climate Settings" to make changes.
6. Ensure your tires are at the proper pressure – Proper tire pressure not only works to maximize range, it also works to help ensure that the correct amount of tire surface area is gripping the road. Tires that are over or underinflated can lead to range degradation along with safety and performance issues.
You can find the proper tire pressure figures for your vehicle using the sticker on the sticker inside the driver door. Likewise, higher speeds can negatively impact range in all types of weather. For best results, Ford recommends limiting your speed when possible.
By following these winter driving tips, you can help to ensure that your electric vehicle is prepared to tackle the challenges of colder weather. With new technology like Ford’s Vapor Injection Heat Pump, found in 2024 F-150 Lightning pickups and soon-to-be-launched 2025 Mustang Mach-E SUVs, Ford vehicles are better equipped than ever to optimize performance in cold conditions. And as electric vehicle adoption continues in the U.S., staying informed and prepared is more important than ever.
If you’re ever unsure about living with your electric vehicle, Ford owners can also text a dedicated Ford advisor for 24/7 electric vehicle support.
Stay warm and happy driving!
Guss-E 2021
Pierre
New Hampshire
2022 Mach-E Prem AWD ER
Compliance Specialist
I'm sorry you folks need to be in the office 5 days a week.
You're sorry, ? . At least we do 4 o'clock Fridays at my job.
Deleted member 19354
Guest
Thank you. I called BEV spoke to Gregory and they had no clue what preconditioning was.
I use level 1 and have had conflicting answers. Yes level 1 will precondition and No level 2 will not.
Frustration mounts.
67 Stang Convertible
Rich
Georgia, USA
Physician
Frustration mounts.
Robert, You will get much better info here on the forum than calling Ford!!
MellowJohnny
Christian
YYZ
Solution Architect
Frustration mounts.
Level 1 will not supply enough juice for meaningful preconditioning - pretty sure @Mach-Lee has tested this years ago.
johnnycombo
Pennsylvania
Hey how can I get the remote start climate settings in FordPass?
For the iPhone, open the App Store, search FordPass, select the FordPass app page. The page will have a button that says open or update. My app says version 5.9.0, 1 week ago.
FriendlyLightning
Kolton
Northeastern Arizona
2024 Mach-E GT
Android Auto inclusion is news to me. I wonder why CarPlay isn't given this functionality too. The linked article on Ford's website specifically excludes it. Bummer since Apple Maps seemed to embrace EV-centric features far sooner than other mainstream competitors.
Sikkun
2023 Mach E
Because Apple has thus far refused to enable it.
