Was it implemented better than Google? Google was dumb you look at an area of a map and say download. When I was traveling along the coast of CA and into Oregon I had to do a lot of moving and downloading vs just saying download these 2 states. Boom Done! Your image seems to imply you can download larger areas. The automatic updates is a nice touch.Don't forget in iOS17 you can now have Apple Maps download a set area to your phone in case you drop out of cellular range (no more driving on a beige grid when signal drops out) Essentially offline maps - which is a long overdue feature.
You can go in and set which connector your car uses.No point in listing Chademo chargers.
How’s PAAK working so far on the beta?I installed the beta. Here’s what it looks like… It says there were 17 chargers (seems like a lot?). So that top “Chargers” number must be the number available.
I think the implementation is slightly better in AppleMaps over the way Google did it.Was it implemented better than Google? Google was dumb you look at an area of a map and say download. When I was traveling along the coast of CA and into Oregon I had to do a lot of moving and downloading vs just saying download these 2 states. Boom Done! Your image seems to imply you can download larger areas. The automatic updates is a nice touch.
PAAK has never worked amazingly for me... As far as I can tell, it’s functioning as good as it was pre-beta.How’s PAAK working so far on the beta?
That would be great, but how about even just a notice when using the built in nav that preconditioning has started?So I guess Ford needs to add hooks into battery preconditioning so that Apple Maps and other similar systems can tell the car that it’s on the way to a charger and to start preconditioning the battery N number of minutes out from that charger. ??
Yes, and definitely send feedback for tweaks. If you're in the beta, this is part of the job you signed up for without knowing.Time for an iPhone upgrade as my trusted 8 Plus will no longer be supported in iOS 17. Well, I got the full 5 year run out of it.
If we want things added, send feedback to Apple.
Thank you!Yes, and definitely send feedback for tweaks. If you're in the beta, this is part of the job you signed up for without knowing.
Here are some screenshots of the new UI.
