iPhone 13 Pro compatibility
Mathington
Canada
Mach-E Premium SR AWD
I have the iPhone 13 Pro Max and it works just fine with my Mach-E and iOS 15.
back_at_it_19
Seattle area
'21 Job 1 GB FE and '22 Red Prem4x
Understandable, but In my case they are the same. I have a 13pro max that didn’t work before I updated to iOS 15 and still doesn’t work after. Same for my wife’s 13 pro. My 11 on iOS 14 worked fine. I do fortunately have PaaK and it works great now. However, my Bluetooth connection is constantly fighting with the WiFi connection and I think that is what is preventing me from using CarPlay. I can’t even plug it in and use it. This is very frustrating. I did a master Reset and it didn’t help. Excited to take my car in for warranty because CarPlay is not working.
Apple had a CarPlay bug in ios15. There is an unnumbered update ios15 that seems to have fixed the issue. Delete old phone from car and paak on the app and start over after restarting updated iPhone. All good here.
SEMacheE
Eric
2015 Ford Super Duty, 2021 Premium Mach-E x4
Military
How did you get to the unnumbered update? When I go to software update in settings it shows my phone as being up to date. Is there a trick to getting another update outside of what I have already?
back_at_it_19
Seattle area
If it says ur up to date u prob already updated. It comes with ios15 and prompts u to upgrade to ios15.
SEMacheE
Eric
Military
Ok, thanks for the info. I'll keep messing around with it in hopes that it just magically starts to work.
Tap on Software Version under Settings General About to see the detailed iOS build on your iPhone.
SEMacheE
Eric
Military
Thanks, found it. It's Software version 15.0. I have read that turning off the EQ is a work around to fix the connection issues but otherwise 15.1 is allegedly going to correct the issue. It appears there are plenty of other folks having the same issue in different make/model vehicles.
Right, but tap on ā€œSofteare Versionā€. You’ll see a more detailed version than just 15.0 ?
SEMacheE
Eric
Military
? 15.0 (19A346)
Thesmoothdome
2021 Star White Metallic Premium eRWD
Anyone have a problem connecting with the new iPhone 13 pro? I tried to set it up and got a "device not supported" warning on FordPass. The phone actually did finally connect as a key after repeated attempts, but it it does not work as good as my old iPhone 11 and the Bluetooth and apple car play disconnect repeatedly.
This is my wife's phone and she is now using the FOB as a key. I have the 13 Pro max on the way and I use PAK all the time with my 11 so I am hoping this is not a real problem. Just curious if maybe its just me, or the car needing an update.
I've been struggling with my iphone 13 pro max and carplay as well. Tried all the different suggestions I could find including removing the phone from the car and the car from the phone and installing ios15.1. Nothing worked until I turned off the damn EQ on the phone. Can't be sure if just the EQ off will fix the bug on a ios15, but if I had to do over again, I'd start with turning the EQ (and late night) off.
I can test it tonight on my wife's iphone 13 since I still need to set her PAAK and carplay up.
agoldman
Charleston, SC
There are know bugs in ios 15 and carplay. Expect fixes from Apple in the next couple point updates.
JohnnyForensic
VA, US
Digital Forensics
I have no idea, but I had to update to iOS 15 on both my wife's pro and my pro max.
That's bizarre, as they shipped with 15.0 Release Candidate. I had to update to the iOS 15 final build; that might be what you saw.
I can tell you my 13 Pro Max works perfectly in the MME. What I ended-up doing was erasing all PAAK keys, going into the connectivity settings and wiping out all Ford Connectivity, and removing the phone entirely from the phone list. Then I restored the Ford Connectivity settings, reset the WiFi, and then added the 13 Pro as a brand new phone/first time PAAK routine. Everything works great, and the 13 Pro Max even stays charging on the charging pad unlike my 12 Pro. Good luck!
SEMacheE
Eric
Military
Thanks for that info. I am going to give that a try tomorrow. I have been able to connect to CarPlay by manually connecting to the cars wifi.. But on a positive note PaaK is working great. Hoping for good things tomorrow. Thanks again.
MailGuy
Washington
Bolt Premier, Mini Cooper SE, Mustang Mach E FE
The only thing I noticed (in addition to incompatibility statement) when I paired my new device with PaaK is a more stringent device name requirement. Spaces and apostrophes are no longer allowed in the key name. My iPhone 8 and my wife’s X had no problems even with iOS 15. No go with the 13 Pro. The old key name and App settings initially migrated but when I added the new device after reinstalling the Ford Pass App, the new requirement was enforced for my device.
