Is it safe to shift to drive when still rolling backwards in reverse?
woolsocks
Brad
Minnesota
2023 Mach-E Premium Extended Range eAWD
This is a big no-no in an automatic transmission, but with one pedal driving, I find myself waiting a long time for the car to stop once I've let my foot off the gas rolling backwards out of my driveway. Is it safe to toggle into drive while still moving backwards with an EV "transmission"?
Thanks for your input in advance!
Mr.Meme
Mr. Meme
Cali
Mach-E Premium STD RWD 22
Yes, but I would recommend shifting only when you aren't pressing the brake. If you're in drive or reverse, as soon as you shift into/past neutral it will lock the brakes. This is because it's using regen (motor) braking at low braking force but doesn't use regen braking in Neutral.
So just let off the brakes before you do it, it only let's you do it up to a certain speed anyways. I think past maybe 10 mph you can't shift from D to R.
Yes, if you use 1PD keep your foot on the pedal slightly when you switch gears or the front motor will have a spasm and make loud banging noises (this has been a bug in the software for a long time).
Mr.Meme
Mr. Meme
Cali
Yup, just explained in a reply.
Neutral only uses the brake rotors, so as soon as you shift past neutral it stops regen braking and clamps the piston brakes hard to compensate.
azerik
Chandler/Flagstaff, AZ
DevSecNetOps, General PITA
I do it on my RC Car's all the time. But I really really try not to on this one.
Teslaeata
Nottingham, England, UK
I do it all the time, no problem whatsoever, the car’s systems are sufficiently intelligent to safeguard against any problem, if going too fast it won’t go into opposing gear, just avoid going into Park when moving.
AliRafiee
Ali
Seattle WA
2022 Mach E GT - Grabber Blue
Software Eng.
Above a certain speed it won’t go into park either.
Ravensfan1996
Rick
2021 Mustang Mach E
I’d brake first before switching to Drive. I switched too fast once from R to D and got a tranmission fault. Luckily the fault on the dash went away on the next drive and never had an issue with it since.
Teslaeata
Corrrrrrect! Tried that, too, and at 80mph in an ICE on an investigation. Won’t go into reverse at 80mph either, thank F ?
BudC
Bud
St. Peters MO
2022 Mach-E Select RWD 2024 Kia EV9 GT-Line AWD
I've done it with no ill effects before, but this last time the car started throwing a bunch of brake-related error codes. They did, however, go away the next day - but every time I started the car that same day the errors came up and I lost the power brakes.
Scared the bejesus out of me so I've vowed never to shift so quickly again ?
Flint302
Northern NJ
2021 Mach E Premium AWD, 2016 Audi A3
Retired government
I would say clunks and spasms are not what you want your car doing. I live by two ethos in life: 1. Don't stick sharp pencils into your ears, 2. Don't screw with the gear selector while your car is moving. It's been working out pretty well so far.
Teslaeata
Oh, where’s your sense of adventure ?
