- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Good point, maybe they did scan it yesterday. The codes also go out OTA to the servers when the vehicle is driven. If the vehicle doesn’t drive the codes don’t usually go out and would have to be scanned manually. After the recall updates the codes should go out OTA and the dealer should be able to see them remotely since you are able to drive.I think there might be some miscommunication or poor communication on behalf of the dealer. If @WyldStallyn was able to pull the DTC from FDRS then they likely had to have triaged the vehicle. The car will report the DTC for a bad HVBJB instantly to PTS, but the DTC provided here was the results of a self test performed which had to be done with a physical connection. Unless there's something new that I don't know about, I've only seen Self Test DTCs in FDRS through physical connections.
