Keypad second digit
rodbin
rodney
UK
Mache Jaguar Triumph Mini
Coffee
Just got MMEGT had Mme before 3 years never used keypad thought I would try with the new car I remember that to get second digit you had to press twice I have tried that then hitting 3-4 but no open door searched internet and the forum but can't find if I am doing it correctly
FordMachEGo
SoCal
2021 Premium AWDx April 2021 build.
No you don’t hit the button twice to get the second digit on the keypad. Just hit each button once. 1 is the same as 2, 3 is the same as 4 etc.
Space_Pony
Indiana
2026 Premium Mach-E eawd
Did you read that in the manual?
You're remembering things that aren't correct, sorry.
For example:
1357 = 2468
rodbin
rodbin
rodney
UK
Coffee
Manual says "
"Enter the factory-set seven-digit code or your personal code. You must press each number within five seconds of each other.
Note: All doors unlock if the two-stage unlocking feature is disabled. See Keyless Entry Settings .
Unlocking All Doors
Enter the factory-set code or your personal code, then press 3-4 within five seconds"
I have 5 digit andit does not say how to get second digit i.e if you want 4
rodbin
rodbin
rodney
UK
Coffee
rodbin
rodbin
rodney
UK
Coffee
And I can't count I do have 7
Brilliant thanks.... surely though that decreases possibilities of guessing by 50%
That's the pessimistic view.
The optimistic view is it is a 5 option keypad that provides twice as many options for remembering the code.
AtomicInternet
SC
Focus RS, Mach E Rally
Manual says "
Unlocking All Doors
The door numbers essentially reduce your code to a possibility of 5 digits from 10. Each button represents two numbers.
Ford Mustang Mach-E Keypad second digit 1731600166047-9
EagleDave
San Francisco Bay Area
2021 Mach E
Reduces the number of unique codes way more than 50%
If there were 10 buttons, a 5 digit code would have 100,000 unique combinations.
The MME has 5 buttons, so a 5 digit code has only 3125 unique combinations.
The keypad is temporarily disabled after a few incorrect entries. I don’t recall how many, 5 or 6? I’m not worried about someone guessing my code.
