Latest Graphene from Adam’s Polishes
intensifi
San Mateo
GT
This is the advanced formula with UV light flashlight for application.
Goes on and comes off so easy I decided to go thick. This is the result. Check out the reflection from across the street!
Note I do not use Adam’s applicator pads or removal towels.
Ford Mustang Mach-E Latest Graphene from Adam’s Polishes A671EC84-0E55-4D63-B2B5-F4ACB4AC9DA1
Ford Mustang Mach-E Latest Graphene from Adam’s Polishes 7A33DBC9-A901-49F8-9A38-A7A7BCAE4576
UV light flashlight? WTH is that?
I have a bridge for sale...
It’s easy to miss a spot or seven of ceramic coating when it’s applied. You have only “so” long to wipe it. The UV reveals where the unwiped spots are so you can get them before they harden. Cause then you’re clay baring that area clean and doing it again or pretending you can’t see the excess.
And I really wish I didn’t know this little bit of coating trivia Rick.
intensifi
San Mateo
GT
Richard,
Adam’s has a UV flashlight option. This allows one to apply the compound and not have to worry about high spots that would later need to be polished out If you didn’t catch them at application time.
You can see the high spots and remove them while the compound is still wet.
Enjoy your bridge!
Pushrods&Capacitors
Round Rock, TX
Analyst
Actually….. We got this same Adam’s kit for our son’s black WRX last year. I think I posted here about it. It works as advertised and the UV gimmick does come in handy while applying it. After 9+ months of Texas weather the ceramic seems to be holding up well as he still gets crazy amounts of water beading and the gloss and depth that the application added have not faded at all. Not bad for $139 and a few hours of work.
Pushrods&Capacitors
Round Rock, TX
Analyst
Richard,
Enjoy your bridge!
I assisted my son when he applied his and the UV light does come in handy for knocking down high spots. I was skeptical when we purchased it but it’s legit.
I use Collinite 845, without a flashlight or egg beater. A bottle cost me under $20 like 8 years ago, and it is still 1/2 full despite 2 vehicles, one a truck. Water beads up for over a year. It isn't fire proof, nor radioactive. I think much of this ceramic craze is simply marketing bs.
Pushrods&Capacitors
Round Rock, TX
Analyst
That’s cool. But, our son’s bottle of Adam’s has plenty enough left to do my SS or our MME as well. To each his own I suppose.
Scooby24
Olathe, KS
Perioperative Revenue Manager
I think we've discussed before and while using a product that's like 30 years old is certainly fine, there's a lot of science behind the new stuff and you not understanding how the stuff works doesn't mean it doesn't work. Because it does. You just don't understand it.
doogie63
NC
Mach-E
If you first use ceramic yourself. but then the next year just want to use wax. Is there anything you need to do special before switching to wax?
Scooby24
Olathe, KS
You should polish off the ceramic as waxes don't bond with it like they do paint and they will smear and look streaky.
intensifi
San Mateo
GT
wait for the sealant to wear off.
doogie63
NC
Mach-E
I haven't done ceramic or wax on car yet. Just got the car. Trying to figure out which way I want to go. Either way I will be doing it myself so want a easy to apply either way. Never used ceramic before so not sure I would do it right. I do have a Ryobi buffer so wax would be easier and used wax before.
