LED Accent Lighting
idkhow
Bateman
Jersey
2021 mach-e premium, van down by the river
it plumber, auto detailer
  • Thread starter
  • Banned
  • #1
Couldn't help myself.
Designed LED products & wrote copy for half a decade at Oznium. Used to be *very into glow* and accent lighting, since I got free merchandise to test from Shenzhen direct.
Decided against anything on the outside, but couldn't help myself with some interior glow, hidden well under the dash and front seats.
Paired it to WiFi using the wifi of my car's ATT trial. Also have a backup remote.
Ford Mustang Mach-E LED Accent Lighting IMG_2319
Ford Mustang Mach-E LED Accent Lighting IMG_2290
mdolan92869
Orange County, CA
Retired Software Engineer
I don’t know why, but seeing the coiled cord going up along the side of the display made me think you had a CB radio in there and that was the microphone. ?
idkhow
idkhow
Bateman
Jersey
  • Thread starter
  • Banned
  • #3
Smokey and the Bandit flashbacks.
It's an older Escort Passport 8500 X50, haven't gotten the inline fuse kit in yet. Also passenger footwell is a dash cam I'm 50/50 on keeping (actually like it, a VAVA model)
idkhow
idkhow
Bateman
Jersey
  • Thread starter
  • Banned
  • #6
They mount pretty easily to the driver and passenger front seats which have a stable surface to mount on. I ended up using these for $25 bucks to get front of driver and front of drivers seat. Another set for the rear of drivers seat (doubled up)
B25Nut
Charlee
Templeton, CA
www.bsi-inc.com
2021 Premium MME 4EX Star White, 2019 Acura RDX,
BSI Sales and Technical Manager
I used 3M's heavy duty mounting tape on top of the tape that was included on the strips (which is inadequate) and put them on the bottom rear bar that forms the framework of the seats.
rgbeffa
Ryan
Festus
Ford Mach e
IT Manager
Question on your LED lights in the Mach e. What model of Mach e do you have? I just got into a Select and noticed quickly that it does not have ambient light on the screen. Did you add that and if so how did you add Ambient light to your software to show as a feature. How did you power your LED lights that you installed? Curios if you have step by step instructions.
kdryden99
Richard
Montreal Canada
Ambient lighting is offered on the Premium. He doesn't control the lighting from the dash. You can see in his picture the lights are a different color.
WildfireOne
First Edition
This is a $14 set of LEDs from Costco that plugs into the 12v source in the center console.
Thanks for sharing!
Are you referring to the 12v in the center console BIN, which is a solid piece of plastic? The only way out of that thing without drilling holes is to have the cables powering the LEDs coming out of the top, near the front so that the sliding cover can mostly close... Is that your setup?
B25Nut
Charlee
Templeton, CA
www.bsi-inc.com
Yes, that is how I did it. It is hard to notice that the cover isn't closed all the way.
sgriffin130
Thompson Station, TN
'22 Red Mach E- C/T Pkg, '23 Escape PHEV/Prem Pkg
Dentist(retired)
If the set has USB plug (like the one he purchased) (less heat) you could also use the USB port behind the console with an angled USB attachment if you don't want the cord coming out of the console. Less chance of getting bumped in the console tho.
