- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
The big difference between a hybrid and a BEV is the hybrid will cycle the pack way more times, so capacity retention becomes much more important in a hybrid. A cycle is one complete drain and recharge. If you drive 200 miles a hybrid, that could cycle the pack 10 times, whereas a BEV would only be one cycle. Typical lithium battery life is about 500-1000 cycles, which means the battery in a hybrid might wear out in only 20,000 miles if protection measures aren't taken. Therefore you see a 40-70% limit programmed into it so the pack will last 100,000+ miles. If you kept your BEV between 40-70% the battery would last forever, but it wouldn't be practical due to the short range available. Therefore it's okay to go further into the pack and still have it last 100,000 miles since the pack is much larger. If you want to make 100,000 miles for sure, keep it between 10-90% 99% of the time. If you want more like 200,000 miles keep it between 20-80% 99% of the time.Also, I know that in the Powerboost, the hybrid algorithm keeps our battery's reported SoC% between ~40% at the low end, and 60% as the cutoff where ICE won't charge it anymore, and regen braking charging stops around 70%. Basically it keeps the battery always 40-70%! So Ford intentionally keeps it in that band to extend the life. In watches/phones, the IC's used for charging algorithms are really good about using all kinds of conditions to not overwear or kill the Li-ion cells when up near 100% or down around 0%, but I know NOTHING about how EV's do it.
Charge limits are all about how long the pack needs to last before replacement. It's a balance between having range and preserving the pack. Using the entire battery (100% to single digits) on a regular basis will degrade the pack quickly, you'll probably be below 80% health before you hit 100,000 miles. 70% is the threshold for warranty replacement, but most people will be sick of the poor energy delivery long before that. At 70% health the car will accelerate much more slowly than when it was new, so you really want to make sure your battery stays above 85% health for normal performance while you own it.
