FrankM1
- Frank
- Aug 5, 2024
- Utah
- 2023 Mach E Premium
Scenario: Say your LVB died. You get your power pack and jump to open the Frunk. You then proceed to jump the LVB. The door unlocks and the car starts. My question is: If I remove the jump start on the LVB, will the car keep running? Theoretically the HVB via Converter is supplying about 14 VDC to charge the battery. If this were the case, could I drive off running on the converted power (assuming the vehicle is not turned off)? Would there be enough current to supply the needs of the 12 V system. I, we can come up with a lot of theories but has anybody actually tried this?
