Chiefsfan
William
chesterfield, mo
Lexus GS350
Here's a starting point on a checklist that I've been using on mine:
Mach E Checklist
External
  • Validate VIN
  • Check every seam and door for alignment
  • Open and close every door, trunk, frunk several times.
  • Check undercarriage and all body/fascia edges for scratches or dents
  • Check tire pressures and compare with tire pressure monitor
  • Check lights, turn signals, etc
  • Check headlight alignment
  • Charge port and charge status indicator
  • Check windshield washer fluid level
  • Check windshield wipers and washers
  • Inspect mirrors
  • Fold and unfold mirrors, checking for noise
  • Check puddle lights
  • Check glass roof & margins
  • Check all windows
  • Check front license plate holder
  • Check frunk divider installation
  • Remove the rear luggage compartment cover
    • Check brake fluid level
    • Check coolant level
Internal & Electronics Systems
  • Ensure the mobile charger is in the trunk
  • Test mobile charger
  • Ensure tire inflator kit is in the trunk
  • Check seats
  • Test seat headrests
  • Test rear seat unlatch/latch
  • Test controls on automatic front seats (and manual passenger in Select)
  • Check interior door panels
  • Check headliner
  • Check all interior lights
  • Check glove box
  • Raise and lower all windows a few times from driver controls
  • Raise and lower all windows from local controls
  • Insert and remove every seatbelt several times.
  • Check tire inflator kit age in infotainment screen
  • Turn on the music to check it works
  • Test Qi charger and USB ports
  • Test 12v outlets
  • Driver Display whine?
  • Is battery at 100% State of Charge?
  • Reset EV range and trip odometers
  • Check the center console is working in both dark and light modes
  • Check screen responsiveness
  • Reset the Sync4 (Volume down, right seek arrow, hold for 10 sec. why? just for fun?)
  • Run Bezel diagnostics (Radio on AM or FM, Volume down, left seek arrow)
  • Check A/C, heater, defroster
  • Test keyless entry and start codes from card
  • Program the passcodes for door and car start right there
  • Sign onto FordPass and make sure the car is synced with that
  • Pair phone using bluetooth
  • Check backup, 360 cameras
  • Test Navigation on screen and voice command
  • Activate modem
  • Test radio, Sirius, streaming
  • Test Apple Car Play / Android Auto
  • Check sound in all speakers
  • Test seat heaters, steering wheel heater
  • If the car was built before 1/9/2021, has it been tested per https://www.macheforum.com/site/thr...software-calibration-update.3364/post-106046?
Driving
  • Test Cruise
  • Test Adaptive Cruise
  • Test Intelligent Cruise
  • Test lane centering
  • Test hands off wheel warning
  • Test blind spot sensors
Personalization
  • Adjust the seats
  • Adjust the steering wheel stalk
  • Adjust the mirrors
  • Ensure phone as a key works right there
  • Ensure key fob works
Other
  • Check owner publications and keyless entry codes
  • Run through my financing spreadsheet, verifying each item
That’s quite a checklist
UW2
Los Angeles
Mustang Mach E FE
Mach E Checklist
External
  • Validate VIN
  • Inspect mirrors
  • Check all windows
  • Check seats
  • Check headliner
  • Check glove box
  • Test 12v outlets
  • Activate modem
Driving
  • Test Cruise
Personalization
  • Adjust the seats
Other
Do we have to reset the mileage or something to get the charge/miles to report correctly?
JellyBelly
Kris
MME RR FE
yes to reset so that the transportation from plant based usage is not messing the GOM.
JellyBelly
Kris
MME RR FE
How do we do that again? Thanks
Settings has a drivers history tab or button ... setting to reset. Have find the link
  • Like
Reactions: UW2
crownmountain
Durham NC
2021 Mach-E Premium 2WD ER, 2022 MINI Cooper S EV
Industrial network architect
I was glad I had put it together when I looked underneath and saw this:
That said, I still haven't completely finished the list and some of it clearly takes more time that you can do at the dealership at pickup.
Having worked with several auto companies and having been to several assembly plants. The hardest miles on any car are on the train and the truck. That metal tear is proof.
Tinus
Tinus
Valkenswaard The Netherlands
Mustang mach e
Mach E Checklist
External
  • Validate VIN
  • Inspect mirrors
  • Check all windows
  • Check seats
  • Check headliner
  • Check glove box
  • Test Qi (wireless) phone charger and USB ports
  • Test 12v outlets
  • Activate modem
Driving
  • Test Cruise
Personalization
  • Adjust the seats
Other
Can anybody tell ma how I can get my VIN ??? My dealer only can provite me with the chassisnumber wich is only a part of it.
Your dealer can provide the full VIN. Does the "chassis number" match this VIN length off this FCTP vehicle?
3FMTK3SU9MMA02191
bcraven01
Brett
Liberty, MO
Mach E Premium Standard Range Battery - AWD
Cyber Security
Mach E Checklist
External
  • Validate VIN
  • Inspect mirrors
  • Check all windows
  • Check seats
  • Check headliner
  • Check glove box
  • Test 12v outlets
  • Reset EV range and trip odometers (Settings > Vehicle > EV Driving History Reset.)
  • Activate modem
Driving
  • Test Cruise
Personalization
  • Adjust the seats
Other
@ChasingCoral I dropped this in a Google Sheet. Users can print or make a copy if they need it and we can add to it as we go. Let me know and I can give you edit access.
