Mach E GT unbridled extended
  • Thread starter Deleted member 19354
  • Start date
  • Watchers 3
Guest
Welp last night I was running errands. Freeway was light so switched to Unbridled Extended. After about 2min on the freeway I pulled to the side and went back to unbridled. Where are my clean underwear?
Ford Mustang Mach-E Mach E GT unbridled extended IMG_0562
garyd9
Gary
Pittsburgh, PA (USA)
2023 Mach-E GT
I have yet to try unbridled "extended" on my car. The documentation is extremely vague on what it does/changes (and I haven't found any info on it elsewhere.)
Unbridled Extend is actually slower than Unbridled. It limits max power, reduces regenerative braking to nil, and cuts traction control. It’s still lots of fun. ??
The lack of traction control was the thing for me. Never again.
I just hit the switch to turn it off once in a while for fun. Makes the tail wag. ??
ack154
2023 Mach-E GT PE
Are you pressing it once just to turn off traction control or are you holding down to turn off traction control AND stability control?
The latter option is way more fun (and I believe what the extended mode is turning off or at least significantly reducing).
Holding it down, of course! The came would be zero fun if I can’t make it do things my Firebird can do with more torque going through the rear tires alone. ??
david_quick
Bremerton WA
2023 Mach E GT
I have tried to turn it on but it is always grayed out. What are the required conditions to turn it on?
Guest
It reads the “environmental conditions”. I know once it would not work when it was misting outside
HV battery State of Charge has to be sufficient. HVB temperature has to be in a proper range. ?‍♂?
Teslawho
Monterey CA
2023 Mach-E GTPE Vapor Blue Metallic
It always unknown when i can turn my on. Honestly if your not tracking it whats the point. When i turn it on i instantly get about 10 jailbars meaning it limits my power and yes i know its for track use so you have more consistent power but trust me you dont need unbridled extended. Normal unbridled doesnt give me any jail bars.
Ford Motor Company
Official Ford Account
Glad you're okay, Robert! We'd be more than happy to help you get the handle on that beautiful Mach-E for all your future adventures by scheduling a one-on-one guided virtual tour. Feel free to send us a DM if you're interested in that!
