Mach-E not charging to setting
acoots
Rock Falls, IL
Mustang Mach 3 2021
I recently changed my charging setting from charging to 70% to charging to 90% while plugged in at home. But it will only charge to 88%.
Anyone else having a similar issue?
Thanks in advance
cujo70056
Darryl
Menifee, Ca
MME gt
Maintenance
I have the same issue, I read to delete the location (ie home) and redo, haven't had a chance to mess with yet
ChuckA
Chuck
North Branford, CT
ā€˜21 MME Premium AWD ER in Infinite Blue
Accountant-Retired
Thanks in advance
I once thought I had this problem but then noticed that on the FordPass app the Home page had different info then the Vehicle page.
Seems that Vehicle page updates before Home page, so I was at 90% although Home still showed 88%. So my problem was I had no problem.
acoots
Rock Falls, IL
Mustang Mach 3 2021
Hi ChuchA,
When I get in the car, my actually % on my dash shows only 88%. That is also was is showing on my app as well. I feel like I still have a problem.
Hi ChuchA,
It probably stopped charging at 90% and then dropped to 88% by the time you got in the car. BMS will update % based on temp changes or after cell balancing. Since you normally only charge to 70% it will take a few days for the balancing to adjust to being charged to 90% daily instead of 70%.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
Hi ChuchA,
Are you preconditioning the MME after taking it off the charger? You’re correct that my suggestion doesn’t apply to your situation but to be within SOC 2% is curious.
acoots
Rock Falls, IL
Mustang Mach 3 2021
Today is charged to 89%, so I'll wait a few more days to see if it will reach 90%, but that seems odd that it would not charge to exactly what you want it to. When I want to charge to 100%, it always charges to 100%. Sorry, but I'm not familiar with what preconditioning is after charging.
ChuckA
Chuck
North Branford, CT
Accountant-Retired
It means using remote start from the FordPass app and running the MME for 10 minutes (or less) without being plugged into the charger.
I’m set to charge to 90% at home. Sometimes I see 89, sometimes 91, rarely 92. Rounding, overshoot, temperature fluctuations, etc. I don’t worry about it.
