Administrator
Administrator
Staff member
Mach-E
Official writeup by Ford:
Roads Change With the Seasons. Your Drive Shouldn't
May 12, 2026
If you live anywhere that gets real winter, you know what May looks like on the roads: the aftermath. Potholes patched with fresh asphalt, construction cones multiplying overnight, and pavement still recovering from months of punishment.
For us on the Mustang Mach-E engineering team, this isn't just a seasonal obstacle course; it's exactly what we engineer for.
Every Mustang Mach-E model is designed to handle the real world. That's a given. But how do you create a driving experience that matches every type of driver?
You don't design just one suspension personality. You engineer four.
Ford Mustang Mach-E Mach-E Suspensions: Rally, GT (MagneRide / Passive), Select/Premium Screenshot 2026-05-12 at 7.19.04 AM
With the 2026 Mustang Mach-E lineup, we feature distinct suspension personalities, each tuned to reflect real-life driving behaviors and needs. It’s the same Mustang Mach-E platform, but the experience behind the wheel is completely different depending on which trim series you choose.
The Philosophy: Tuned for How You Drive
These distinct suspension personalities might seem ambitious, but we see it as a commitment to our customers. Different drivers have different priorities, and each Mustang Mach-E trim series is intentionally engineered to meet them.
  • Rally: For "Proven Versatility, On and Off Pavement"
  • GT (MagneRide): For "Intelligent Adaptability" in real-time.
  • GT (Passive): For "Connected and Responsive" engagement.
  • Select/Premium: For "Confident Comfort" and shared journeys.
Adaptive Performance: Mustang Mach-E GT With MagneRide
Here's where performance and comfort come together. Mustang Mach-E GT is available with a MagneRide® Damping System through the Performance and Handling Package, giving drivers the connected, engaging feel of the GT trim with the added breadth of everyday comfort and drivability.
With selectable drive modes, you can tailor the experience to match the moment.
MagneRide is a continuously controlled damping system. The dampers use a specialized fluid that responds to magnetic fields.
When an electric current is applied to the damper, its behavior changes nearly instantly, going from soft to firm in milliseconds. It's an electronically controlled system that adapts in real time to how you're driving and what the road throws at you.
Sensors monitor body and wheel motion up to a thousand times per second. Whether you encounter a rough patch of road or push through a corner, the system adjusts accordingly, working in the background so the driving experience stays composed and controlled.
Combined with other vehicle data, the system can make changes to each corner independently in milliseconds, delivering truly intelligent, real-time adaptability.
Proven Versatility: Mustang Mach-E Rally With MagneRide
Mustang Mach-E Rally takes MagneRide and adds hardware changes to expand the capability even further. With these changes, Mustang Mach-E Rally is designed to say "yes." Can it carve canyon roads? Yes. Can it confidently handle maintained dirt roads? Also, yes.
Ford Mustang Mach-E Mach-E Suspensions: Rally, GT (MagneRide / Passive), Select/Premium Screenshot 2026-05-12 at 7.20.29 AM
That extra suspension travel allows Mustang Mach-E Rally to soak up impacts that might be more noticeable in a vehicle without MagneRide's adaptive damping.
Matt Hubbard, who led the suspension validation testing for Mustang Mach-E, adds: "Rally underwent significant off-pavement testing; we really put the vehicle through the wringer. The combination of hardware robustness and MagneRide adaptability proved itself over and over.
The Performance Option: Mustang Mach-E GT With Passive Suspension
Mustang Mach-E GT is more driver-focused. Like Select and Premium, it uses a passive suspension architecture, but the similarities largely end there. Mustang Mach-E GT suspension is calibrated to create a "Connected and Responsive" feel for drivers who want to be more in-tune with the road.
Where Mustang Mach-E Select and Premium prioritize a balanced, comfort-oriented ride for shared journeys, the tuning on Mustang Mach-E GT trades some of that cushion for sharper road holding, more confident cornering, and a steering feel that keeps you connected to what the tires are doing.
It's the step up for the driver who wants to feel more engaged and capable behind the wheel.
Designed for Every Day: Mustang Mach-E Select and Premium
Mustang Mach-E Select and Premium share a passive suspension architecture, with springs and dampers specifically calibrated to balance everyday comfort without compromising on the fun-to-drive character that makes it a Mustang.
Ford Mustang Mach-E Mach-E Suspensions: Rally, GT (MagneRide / Passive), Select/Premium Screenshot 2026-05-12 at 7.21.30 AM
Matt Hubbard shared insight into how these models hold up:
"Before we launched Mustang Mach-E, we put these vehicles through extensive testing at our proving grounds, driving on purposely rough surfaces designed to simulate years of driving on challenging roads. The passive suspension on Select and Premium is engineered to handle the real world, just like our other offerings."
None of these are compromises. From the very start of development, we set out to engineer each Mustang Mach-E trim series for a distinct type of driver, not just a spec sheet.
That means the experience behind the wheel always matches the intention behind the engineering.
Roads shift with every season. Frost, thaw, fresh pavement, and everything in between.
Whichever Mustang Mach-E you choose, the suspension personality underneath you was created for exactly that.
Matthew Gabrielli is Mustang Mach-E Chief Program Engineer at Ford.
SaintPaulMustangMach-E_GT
Saint Paul
Mustang Mach-E GT
IT Manager
3 years with my Mach-E GT standard suspension in MN winters.
YIKES, it's the single worst feature.
Potholes, snowy and rutted streets, you feel through your bones every bit of the road.
"GT (Passive): For "Connected and Responsive" engagement." Your bones are engaged.
jefftuck
Jeff
US
2023 Mach-e GT
Right. I don’t know if the 2026 changed anything, but the older GT suspension is the worst part of the car. Look at everyone spending thousands to change out the suspension, not to have a better track day, but simply to enjoy the ride on regular roads. It’s a pretty hard putt to spin the GT suspension as a feature of the car.
Mache_Nor
Norway
MachE LR RWD
I think the Ford Engineers should check out the Rally Spring mod thread to see how we all feel about the suspension. I love the car, hate the bounce.
It should come with the same warning as roller coasters; no pregnant or people with sort of health issues in the back. It’s rough 😬
KennyMc
Ken
2025 Mach E Premium, 2025 Hyundai Ioniq5, 2025 Husky FE501s, 2022 KTM 500EXC
"For your safety, remain seated with your seat belt fastened, keeping your hands, arms, feet, and legs inside the bobsled. And please, watch your kids. Thank you!" 😅
inmyrightmind
Matt
Northern Ohio
2024 Mach-e Rally (white)
I bought the Rally specifically for the magnetic suspension and long shock travel - to handle the pothole roads of Northern, Ohio. Even when you’re on some of the roads, it feels like you’re off-road! I am very happy with my purchase decision!
Aahhcc11
Y
Mach E Premium Nite Pony
I’ve had my 2023 premium for over two years now and there is one thing I hate about the vehicle — the suspension. Ok I lied there are two things — the suspension, and the lack of a physical trunk button.
Anyhow the bumpiness and stiffness of the ride is jarring. I go over little bumps and potholes and it feels like I’m going 55 mph over a speed bump. The weight of the battery makes it even worse.
My wife hates it even more. Which means I hate it even more.
#SuspensionFail
SpaceEVDriver
Planetary Science
If I can’t get a set of the back-ordered Rally springs soon for our CA-Rt1, my partner is likely to trade in our ’22 Mustang for a different brand BEV SUV with higher clearance and better washboard behavior. The Rivian R2 is looking better and better to her every day those springs are backordered…
markboris
Sonora, CA
I just got a set from Tasca Parts last week. The rears came off of backorder. Are they on backorder again?
SpaceEVDriver
Planetary Science
I didn’t check before I ranted. 😂🤣
I’ll go look.
SpaceEVDriver
Planetary Science
Tasca says they have them.
CB1234
2022 Mach-E Premium AWD ER
I love everything about my 2022 Premium except:
-the suspension
-the suspension
-no pre-condition button
-the suspension
My daughter has to ride in the front because she gets carsick in the back with all the bone-rattling bumps.
Beyond that, it's my favorite car I've ever owned. So it's kind of amusing to read about how Ford carefully designed the absolute worst part of an otherwise great car.
JonathanEzor
Long Island, NY
2025 MME Rally, 2018 Chrysler Pacifica Hybrid
Same here; when the time came this spring to either keep or get rid of my 2022 GT (non-PE), the suspension led my wife (my most frequent passenger) to veto keeping it. Instead, a 2025 Rally was just the thing, with pretty much all of the great features of my 2022 GT, plus a far more compliant suspension to keep my passengers happy.
