DadzBoyz
- Dan
- Jun 6, 2022
- Oldsmar, FL
- 22 Mustang Mach-E GTPE (ordered), 20 Mazda CX-5
- Software Systems Integrator
(Disclaimer: Yes. This article is behind a paywall. I'll explain the jest of it.)
"U.S. scientists say they have produced the first commercially accessible material that eliminates the loss of energy as electricity moves along a wire, a breakthrough that could mean longer-lasting batteries, more-efficient power grids and improved high-speed trains."
This has been all over tech and science news, recently.
The University of Rochester, in NY, just had a paper published that explains/proves that they have discovered a material (mixture of hydrogen and a material called lutetium) that can exist as a Superconductor at room temperature. This is VERY significant. In another thread, I tried to share that the batteries, wiring, motors, etc. in current EV's (and electronics in general) are not close to efficient. This is because existing materials used in these things have different levels of resistance. This resistance creates heat and a loss of energy/electricity as it travels.
I am not an electrical engineer. That said, I think I understand enough about the subject to provide some layman level examples. The numbers are only for mathematical purposes and not specific to any particular EV or device.
Example 1
When we plug our EV's in to charge, the power/energy follows this path once it arrives at our homes:
Fuse Box -> Cable -> EVSE (Electric Vehicle Supply Equipment) -> Cable -> Charge Port -> Cable -> AC or DC Charger -> Cable -> AC/DC inverter -> Cable -> Contactor -> Cable -> Battery
There is energy lost in every step of this process. Each component is made of a material that has some resistance. That resistance creates heat, which is, in essence, lost energy. So, the EVSE can send energy at a rate of 11 kW, but each step in that process reduces that amount a little bit due to resistance. Buy the time it makes it to the battery, that rate may only be 8kW which is 72% efficient, or a 28% loss of energy.
Example 2
While driving, the batteries on our EV's may provide 2 kW of energy. By the time those 2 kW leave the battery, travel over a wire, travel through contactors, travel through another wire to the motor... because of the resistance and heart in all of those material components, the motor may only receive 1.2 kW. This rough example is only 60% efficient. 40% of energy is lost on the way from storage to use.
THE GOOD NEWS
A Superconductor material allows energy to move across it with no loss. GREAT!
To this point, Superconductive materials that have been discovered have required that they be made at 145,000psi and their temperature be at aound -320 degrees. Umm, not so great.
The metal would have to be created at a pressure of about 1/360th of the pressure of Earth's core and I'd have to keep my phone, car, etc. components at -320 degrees to take advantage of a Superconductor. Not practical.
The new superconducting material that was discovered by the scientist at Rochester University can be created at a pressure about 1/1000th the pressure compared to the prior material and works at around room temperature (around 69 degrees).
THIS, WE CAN USE. These are parameters that can be industrialized and produced. A study co-author said:
The article goes on to say:
It also talks about how this could help tackle climate change by:
(Kelvin also being a unit of measure for temperature.)
https://apple.news/AxQw8gEgBRD-i00WoSRsQ8Q
Example 1
Example 2
THE GOOD NEWS
“We will have devices with superconducting components in them in the next five years."
"That means our phones and laptops will need less electricity to run, and not lose energy as heat—giving them longer battery life. The same components could be incorporated into electric-car batteries."
- Allowing energy transmission without loss
- Energy storage indefinitely without loss
- Reduce cooling system requirements for Fusion energy containment fields
- etc.
