cloud9
- Gary
- Apr 25, 2021
- Sioux Falls, SD
- 19 Bullitt, 19Edge ST, 21 Explorer ST ,21 MMEGTPE
I spent time on the track with one of the engineers running B302 lap times below the track's benchmark time to carve your name in the table. I told him we were having issues keeping the cars cool, and he was surprised saying they were thoroughly tested preproduction, and didn't overheat. After testing larger radiators, grille replacements, Tiger ventilated hoods, brake cooling ducts/hoses and other cooling mods we collectively as a group finally fixed it. A bunch of us went to Chuckwalla and rented their school cars for a couple days and found they had installed Afco dual fan heat exchangers along with a grille swap and were able to keep them cool in the desert heat East of Indio, CA. I had the same issue running my S197 GT500 on track and ultimately in addition to running a larger radiator and heat exchanger, had to have a blower pulley setup that allowed me to run a larger pulley on the track to lower the boost. I spoke with one of the professional race drivers of the Ford GTs (2005-2006 era) who said they were constantly battling heat soak during their races and having to modify. Add in the MT82 transmission issues on the Coyote era cars and the grenading stock clutches and yes there's a history of needing significant upgrades if you're going to push them "as advertised".Over the past number of years Ford has demonstrated a pattern of emphasizing, ie. hyping, Mustang track capabilities, only to have significant flaws emerge once in the hands of actual customers. One was in the first generation Coyote-powered cars which couldn't be shifted at redline because the transmission locked up. Then there was the track-bred GT350 which would overheat and go into limp mode half way through a 20 minute track session. Both of these led to lawsuits. Neither condition was acknowledged by Ford, nor was any remedy offered other than buying a newer model which had the problems rectified.
