ATL
- Aug 27, 2022
- Canada
- 1979 Trans Am, 2016 Mustang GT
- Electrical Engineer
The real hazard here is time and complacency. If everything is done perfectly using best practice and top grade equipment and materials, then it may perform well...for now. Keep up your vigilance, though, to be certain you catch any degradation in performance leading to overheating and/or pending failure of the outlet. This will be the biggest risk of pushing the rules and ratings to their limits every time you charge. Even that industrial grade outlet will eventually relax its contact pressure, potentiality resulting in increased contact resistance and resultant heat buildup.It's against code to have a 60A breaker protecting a 50A outlet. My MME only draws 46A max (10.8KW) even thought the EVSE can supply 48A. It's the limitation of the MME's internal charging hardware as indicated in the specs. A breaker should handle it's rating (50A) indefinitely.
