Navigation direction box stuck on HUD
Izzle
Seattle
2022 Mus Mach-E GT Performance; 2008 Mustang GT/CS
Does anyone know how to fix this issue? For the past week I have had this box stuck on my HUD screen no matter if I have navigation on or not. Funny part is that I have everything set to miles but it always reads 0km no matter if I'm using navigation or not...
Ford Mustang Mach-E Navigation direction box stuck on HUD IMG20230727081611
bshaw
Boston, MA
Strictly speaking, that is called the Instrument Panel Cluster (IPC).
HUD is something that is projected onto the windshield, and is not something currently available on the MME.
Izzle
Seattle
Thanks for the clarification on "HUD", after I posted this I was reviewing the manual and it's actually called the "instrument cluster display". ?
Any input on the specific issue?
Izzle
Seattle
go into Nav system, select a destination, start the route, then cancel destination. should "reset" everything.
Thank you! I will try that when I get back in the car. Appreciate the response on the issue!
DevSecOps
Todd
CISO
The Mustang Mach E doesn’t have a HUD (Heads-Up Display) ?
I mean we could call the IPC a heads down display. Then HDD might be confused with hard disk drive.
bshaw
Boston, MA
Thanks for the clarification on HUD, any input on the specific issue?
I would say start and cancel a destination using the in-car nav, but it sounds like you've already tried that.
Reboot the center screen, not sure if that will have any effect, but it won't hurt to try.
TuxToaster
Salt Lake City, UT
2021 Infinite Blue MME Premium ER AWD
For anyone else who stumbles on this thread with similar issues, it's worth noting that there seems to be a similar issue if you are using Waze. Switching to Google Maps seemed to work normally so it appears that a recent update in Waze (4.96.1.0) may have broken things, in which case the steps above won't help much.
csilvest
Idaho
'24 Rapid Red GT, '16 Mustang GT Conv
IT Administration
Found this thread searching for info on this problem. It started today on my MME and I've never used Waze in this car or on my current phone, so it's not Waze, or at least not just Waze. Will try the fix above when I drive home later.
lindamclaird
Linda
tiburon, ca.
2022 mach-e
I have this bar also on my 2022 Mustang and don't know how to get rid of it. I called Ford and they told me it showed that there was no car close to me in front and would turn orange if there was a car too close to me. It is on all the time. It just appeared one day.
Sounds like you’re talking about the distance indicator. You can turn that off in the Driver Assistance menu.
