Norway - Mach-E ready for production
janfredrik
Norway
Mach-E
Code:
         "type":"order",
         "contractSource":"Web",
         "gobStatusCode":"VITR",
         "gobStatusDesc":"InTransit",
         "vmacs2CharCode":"91",
         "vmacs3CharCode":"711",
         "vmacsStatusDesc":"COMPOUND IN ",
         "vmacsStatusDate":"2021-04-01 14:44:00.0",
         "gobStatusDate":"2021-02-24 15:57:09.0"
Fikk beskjed av forhandler 26.3 at den var i Nederland.
makooy
Rotterdam, NL
Mach-E RWD SR Lucid Red TP+
IT Consultant
@makooy Not ready yet, try after a few days ... :cool:
Already found another source :D
A bit of the info i now got, still trying to decrypt the rest.
Dont know the numbers for NL, UK, NO, DE etc.
Grande Halifax:
1509x Mustang Mach-E
- at least 414x NL
Grande Houston:
1150x Mustang Mach-E
- at least 130x NL
Grande New Jersey:
263x Mustang Mach-E (nov/dec-2020)
MSC Cristiana
93x Mustang Mach-E (jan-2021)
MSC Immacolata
696x Mustang Mach-E
- at least 116x NL
- at least 311x UK
Gral.San Martin (STX Oriole):
560x Mustang Mach-E
- at least 157x NL
Total = 4271
makooy
Rotterdam, NL
IT Consultant
Code:
         "type":"order",
Was informed by dealer 26.3 that it was in the Netherlands.
Antwerp = NOT Netherlands, it's in Belgium ;)
portlandg
grahame
Dorset UK
Black RWD ER and loving it
Cabinet maker
Grande Halifax:
- at least 414x NL
Grande Houston:
- at least 130x NL
Grande New Jersey:
MSC Cristiana
MSC Immacolata
696x Mustang Mach-E
- at least 116x NL
- at least 311x UK
560x Mustang Mach-E
- at least 157x NL
Totaal = 4271 stuks
Interesting numbers. What is also interesting is that you say there is 560 on Gral San Martin. She has been from Veracruz to Baltimore. Her next stop, according to schedule, is Cotonou, Benin, West Africa and then Lagos.
makooy
Rotterdam, NL
IT Consultant
Correct. But someone else found out that they are discharged in Baltimore and loaded onto the Grande Halifax in Baltimore and then head to Europe on the Grande Halifax.
portlandg
grahame
Dorset UK
Cabinet maker
That is what I thought was going to happen
Machmus
Magnus
Bergen, Norway
CG Mach-E AWD LR, Seat mii Electric
"gobStatusCode":"STRT","gobStatusDesc":"SentToPlant","vmacs2CharCode":"91","vmacs3CharCode":"711","vmacsStatusDesc":"COMPOUND IN ","vmacsStatusDate":"2021-03-31 20:08:00.0","gobStatusDate":"2021-01-29 00:38:10.0"
Da fikk jeg en endring 31.03, etter at status hadde vært uendret siden 01.03.
Det endret seg nĂĄ fra COMPOUND OUT til COMPOUND IN. I tillegg endret det seg fra "92" til "91", og fra "721" til "711".
stesir
Steinar
Norway
RR Mach-E4X, W Mondeo ST AWD
Senior Enginer Telecom/development
Jeg fikk den etterlengtede "på vei"-mailen i går kveld :)) ), og i trackeren har jeg fått Primary Status "Delivered" og "Final Delivered Date" 19. mars;-) Det er vel optimistisk ettersom det nok vil ta 2-3 måneder til før bilen faktisk blir overlevert ... Men nå skjer det i alle fall ganske mye!
Det er tydelig at FE ordre ender opp som Status "Delivered" i trackeren, har jeg sett pĂĄ flere. Disse ble tidlig reservert/bestilt av Ford Norge basset pĂĄ deres Events.
Mulig de er registeret med "Ford Norge" som kunde, og at de får denne statusene når de er planlagt?! eller kommet inn i for QA, eller er fikset på fabrikken før sending ...
Interessant videre er nĂĄ hvordan statusene med F12 pĂĄ vĂĄre Ford Acounts endre seg.
stesir
Steinar
Norway
@stesir: etter at jeg fikk mail fra Ford om at bilen var satt i produksjon, fant jeg dette i koden fra min side pĂĄ Ford:
{"result":{"vin":"WF0TK1E73MMAXXXX","order":{"type":"order","number":"xxxxxxxx","contractSource":"Web","gobStatusCode":"STRT","gobStatusDesc":"SentToPlant","vmacs2CharCode":"1 ","vmacs3CharCode":"121","vmacsStatusDesc":"SEGMENTATION ","vmacsStatusDate":"2021-01-29 17:49:00.0","gobStatusDate":"2021-03-26 19:58:06.0"}},"error":null}.
De datoene stemmer ikke med noe fra seg.fyi eller info fra min forhandler. Bestillingen er registrert 08.01.21, byggedato fra forhandler er 8.april, og i seg.fyi prod.dato er N/A.
Aner du hva 'vmacsStatusDate' og 'gobStatusDate' betyr? Kanskje bilen min ble produsert allerede 26.03., det er jo lov ĂĄ hĂĄpe?
Denne sammenhengen er interessant:
Jeg tror det betyr at den ble sent til feilretting på Fabrikken?! (SentToPlant" - i dette tilfelle), 29. januar, med 1 feil?! (feilkode 121), og ferdigstilt, altså ferdig bygget 26. mars ... (før din forespeilede ferdig bygget dato fra VISTA og forhandler ? :cool: ) - noen andre tolkninger?!
Roger81
Roger
Norway
Ford Edge
{"result":{"vin":"WF0TK3SU9MMAXXXXX","order":{"type":"order","number":"10372XXX",
"gobStatusCode":"VPRT",
"gobStatusDesc":"AtPort",
"vmacsStatusDate":"2021-03-19 16:25:00.0",
"gobStatusDate":"2021-03-26 13:41:43.0"}},"error":null}
Ser ogsĂĄ at det har forandret seg litt hos meg ogsĂĄ
{"result":{"vin":"WF0TK3SU9MMA128XX","order":{"type":"order","number":"103722XX",
"vmacs2CharCode":"92",
"vmacs3CharCode":"721",
"vmacsStatusDesc":"COMPOUND OUT ",
"vmacsStatusDate":"2021-03-28 14:45:00.0",
På de første tallene så sto det på ford.no at bilen var på vei (fikk også epost på det) nå så står bilen i produksjon igjen
Grabber Blue Oslo
Aage
Norway
Mach-E Grabber Blue FE
Automotive technician
Samme her:
{"result":{"vin":"WF0TK3SU0MMA14XXX","order":{"type":"order","number":"10012595","contractSource":"Web","gobStatusCode":"VPRT","gobStatusDesc":"AtPort","vmacs2CharCode":"92","vmacs3CharCode":"721","vmacsStatusDesc":"COMPOUND OUT ","vmacsStatusDate":"2021-03-28 14:45:00.0","gobStatusDate":"2021-03-26 13:43:04.0"}},"error":null}
tormodg
tormodg
Oslo, Norway
Mach-E FE RR delivered 2 July 2021
Gratulerer?! - Jeg prøver meg på en optimistisk tolkning! :D :cool:
Den er klar for å sendes Drammen, her følger ikke Tracker lenger, da den er klar og levert Ford Internt (FE? tatt over fra tidligere? - noen andre FE har jeg og sette dette på)
MEN jeg kan ta feil, du må følge tett opp på Ford Acount med F12 og se hva status sier, + forhandler ... og dele her ...
Tror nok du er litt for optimistisk :D men vi kan jo hĂĄpe. Men dette er en av de FE som Ford Norge annonserte lille julaften, som "60 ĂĄrs jubileum". Jeg fikk da byttet min Premium bestilling i en FE bestilling.
F12 sier nĂĄ:
{"result":{"vin":"WF0TK3SU2MMA129XX","order":{"type":"order","number":"10577979","contractSource":"Web","gobStatusCode":"VPRT","gobStatusDesc":"AtPort","vmacs2CharCode":"8 ","vmacs3CharCode":"631","vmacsStatusDesc":"SHIPPED ","vmacsStatusDate":"2021-03-30 13:00:00.0","gobStatusDate":"2021-04-04 12:04:57.0"}},"error":null}
Har sendt mail til forhandler for å høre hva som er status.
stesir
Steinar
Norway
Ganske mange, vil jeg tro. Fords Emma Berg sa dette 16. mars: "More than half of the Mustang Mach-Es in transit to Europe are on their way to Norway." Ford Mustang Mach-E buyers in Norway wonder about delivery delay (freep.com)
Flott artikkel, bra jobbet. ? Krediterer forumet, tøft!
Ford vil levere, og informasjon er vanskelig, men det kan virke som de følger litt med oss, og gir oss litt mer "skjult" info, som må tolkes, fra sin egen Ford Acount/vår side. - MEN de har et stort forbedrings- potensialer der ...
Ford kunne klart levere dette! - det er annen kompetanse en de som bygger bilene ... Tolkingene og finner en mengde, som forumet ut ... - det tar bare litt mere tid ..., - men sĂĄ treffer "Gruppe analyse" sjelden langt fra mĂĄlet ... ? :cool:
stesir
Steinar
Norway
F12 sier nĂĄ:
Ja, jeg var nok litt for optimist, beklager. Etter ĂĄ ha sett pĂĄ flere kilder, analyser heller jeg mot at din er pĂĄ havnen "VPRT","gobStatusDesc":"AtPort",(i Veracruz, etter fikset kjente QAs?! pĂĄ fabrikken?! - 8 ","vmacs3CharCode":"631") Da din har en prod dato 13. mars ... har den ikke rukket komme til Antrwerpen. F12 vil sikker vise neste status Compound OUT ...
