Outlet in my garage + (linked) adapter + Ford Mobile Charger = Mach e charging?
cmsva1
Infiniti G35
I bought this (NEMA 6-20P to 14-50R) adapter from Amazon. Linked here
Think this setup will work for EV charging with Ford Mobile Charger? This outlet is already in my garage.
Ford Mustang Mach-E Outlet in my garage + (linked) adapter + Ford Mobile Charger = Mach e charging? IMG_5123
Fremont Kid
Colorado Springs, CO
Retired IT
No that won't work.
You need to find a 16A 240V charger/EVSE that's compatible with your current circuit, or hire an electrician to put in a new 50A circuit.
Agree. Consider the voltage and amperage. No reason to connect the 14-50 which is designed for 240V - as I understand it - to a 6-20 plug 120V connection. Also, the 240V 50-60A supply will probably quadruple the miles per hour charge to your MME. My 240V 60A circuit. The electrician chose to install a 60A rather than 50A circuit breaker. This charges my MME at between 18-20 miles per hour, but the 120V 15A connection charges at 3 miles per hour.
That said, converting the electrical supply in volts and amps to kilowatt hours then into miles per hour battery charge is highly dependent on the MME's guess-o-meter (GOM) calculator algorithm, which uses driving history. I've calculated a few times without knowing the algorithm formula, learning that the variance does not provide great accuracy.
i8iridium
Pat
Fort Washington, MD
2022 Mustang Mach E GT
U.S. Air Force
The NEMA 6-20 pictured is a 240v 20A outlet (if wired correctly). Like posted above, it will trip the breaker using that conversion cable. If you get a Tesla portable EVSE with the appropriate NEMA connector and a tesla tap, you could use that. It'll tell the vehicle to only pull 16A on that outlet. Sometimes portable Tesla EVSEs and the NEMA kit can be found on eBay for a decent price. It's a handy kit for your charging toolbox. I have one that I've used extensively on the road.
Tesla Mobile EVSE
https://www.ebay.com/itm/204334380468
Tesla NEMA Kit
https://www.ebay.com/itm/225570208360
Fremont Kid
Retired IT
Tesla Mobile EVSE
Tesla NEMA Kit
Very good.
It’s been 2 years. He either abandoned the idea, or burnt his house down! 😂
cmsva1
cmsva1
Infiniti G35
Ha, thanks for checking in. All is well. 😂 I hired an electrician to put in the 50Amp circuit. I’ve been using the Ford Mobile Charger (as my home charger) for almost two years now.
