Please pick your phone AND pick if you have an issue with PaaK
  • Total voters
    119
DevSecOps
Todd
CISO
First and foremost: This is still a working theory and a few of us are trying to work out the bugs to see if indeed this is a fix for most users. What we know is that there is a module update for the first module in the chain of modules for PaaK. There are many cars that need updates to modules down the line from the RFA module that are also part of PaaK. I will keep this thread updated with our findings. As for now, I have a perfect PaaK experience with a FULLY updated MME. Prior to the update I had the below listed issues.
I originally posted this for those of us that have GT/GTPE models however @benk016 informed me that he noticed the same update being available on his previous FE, which I've since confirmed. This means that the update should be universal across all builds. I will refer to Ben's post here for more information.
If you face these issues:
  • PaaK will take a long time to connect outside of the car when the doors are locked
  • PaaK will take a while to be recognized as a key once inside the car
  • PaaK will not work unless you open the FP App
  • The vehicle will display "Key not found" even after starting the car
I fully updated my MME via FDRS, including an RFA Module update, and after many days using PaaK I can report that the distance that it senses me at is much greater (including walk-a-way, so I had to get used to that) and it has yet to fail or give no key errors. As an additional data point I am using Android.
What I do experience still is a very short delay from deep sleep. If the car has been off for a while I can approach the car without the vehicle knowing I'm there. Touching the door button wakes the car and 1 second later, pressing it again opens the door. This might be expected behavior from a dormant car for battery life.
To perform the update you could do it yourself via the guides and about a 1k investment in hardware or bring it to the dealer. My specific comments and pictures in regards to the update process can be found here.
Fun stats -
VIN Checks Performed - 45
VINs Needing Update - 35
VINs Already Updated - 10
One of the checks was on a GT, not yet delivered and just produced 3 weeks ago. It needed these updates. I would assume all new vehicles need the update even the ones rolling off the line.
Those that had older PaaK updates might need this update as well. There are two RFA module updates for older builds.
For OTA Reference - I've been asked a few times which modules can be updated via OTA. Here's the link.
Other things to try - remember that your phone needs to be excluded from power management features and it should also be given always gps access. By default these settings are not on. Also by default some OS' will only give you "while using the app" permissions. You'll need to manually grant FordPass those access levels. Remember that your phone has to be trying to connect to the car for PaaK to work. DISABLE battery management for the FP App.
Reset PaaK - If you perform the updates I would recommend resetting your PaaK settings which can be done in the car by going to Settings - General - Reset. Do not reset from the phone. This step, while annoying, eliminates a possible point of failure. Just like tech support for many electronics, reboot and reset are often the first steps. Remove the old Bluetooth connections from the phone before attempting to re-pair. The BT connection will not have a name, rather it just has the MAC address of the car's BT radio.
VIN Checks - I've done a lot of them... each one takes about 10 minutes so I'm not going to do any more. After doing so many, there's a clear denominator. If you have had a RFA or PaaK update after July 1, 2021 then you should have all the PaaK updates. If this is you then you most likely have a lot of other updates needed and you should get those installed. If you have never had an RFA or PaaK update then your car will need it (some will need 2 updates for the RFA). This even applies to the ones rolling off the line as of October.
#1 Question Received - How do you get the dealer to update the car. Short answer, I don't know. It's my experience that dealers only want to update what they have to. Unless there's an issue with a TSB or recall I don't suppose they will. You might get lucky, but some of these updates take 2+ hours to complete. Someone has to pay them to do that and without a TSB/Recall to bill back to corporate it's probably not gonna happen.
Neil4Real
It seems pretty easy to do the updates right? The thing I'm hung up on is what power source to hook my 12v battery up to, as that's required, right?
DevSecOps
DevSecOps
Todd
CISO
Yes it's easy. I purchased this and it was super easy to hook up and use. Since I live on many acres of property and have tractors etc, having a good quality battery charger/supply was worth it. I would have been hard pressed to purchase a $500 charger otherwise.
I would have been scared to do the updates without it, now that I've seen how the car drains quickly when it's updating. When you hook up the power supply it isn't actually doing anything and the car sits at about 14.4v. As soon as the update starts the car immediately drops to the voltage set on the supply and the supply kicks on and maintains that voltage.
benk016
Tulsa, Oklahoma
2021 Mustang Mach-E GT
I just successfully updated using Forscan, and can confirm already that I don't get a key not detected error after the car is started and Android Auto connects.
Another note, the version that my GT came with, its the same version that was available as an update on my FE. Which means this file should also work on non-GT models as well.
DevSecOps
DevSecOps
Todd
CISO
You can update with Forscan? Do you still need an FRDS account?
So It's a bit complicated and Ben and I worked through this in DMs. The original files have to come from someone with FDRS who has applied the update on their vehicle, but if you know what to look for you can extract those files from the program data of FDRS and use them with Forscan.
benk016
Tulsa, Oklahoma
You just need a build of forscan that has module programming. And a wired OBDlink EX.
Edit: And the .vbf files as forscan can't source them yet.
Interesting. Do you suppose the car reports back to Ford that the module has been updated even if it’s not done through FDRS?
DevSecOps
DevSecOps
Todd
CISO
Interesting. Do you suppose the car reports back to Ford that the module has been updated even if it’s not done through FRDS?
Doesn't appear that it does.
benk016
Tulsa, Oklahoma
It won't right away for sure like it would with FDRS. It probably will eventually since the car randomly phones home, but we'll see.
DevSecOps
DevSecOps
Todd
CISO
So if I go to the dealer, which update (numbers/name)does he need to perform?
If it were me, I would say that you've been having issues with PaaK and that you were informed that there's an RFA module update that has been known to resolve many of the issues.
I would ask if they could perform the update. Once they plug the car into FDRS it will tell them what is available and if your RFA module has an update it can be performed. So far it appears that nearly all MMEs need the update.
67 Stang Convertible
Rich
Georgia, USA
Physician
I have many of the issues you discussed (key not detected after start, App needs to be on screen to start, with out fob the car needs an extra second to recognize the phone, etc...). However when I 1st got the car PAAK did not work at all. Then I recieved the software patch via the dealer and the phone has not "failed me" since. Do I need this RFA module update in addition to the software patch I already received?
Thx
benk016
Tulsa, Oklahoma
Thx
The PAAK update the dealer did previously resolves a lot of issues for sure. This update seems to make it even more reliable so far. Just no guarantee that your dealer will actually apply it.
RMoore
Rob
Impressive bit of tech work here--I feel like I'm watching a spy movie and you guys are working for the NSA... :)
