Power-up
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
Ford Power-Up
Recall 22S41 & 22S29
We upgraded software on your vehicle to
protect high-voltage battery components from
excessive heat generated during DC fast
charging and repeated full throttle events. This
completes safety recall 22S41.
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
I got this power-up last night and this morning my car is charged to 100%.
I normally charge to 80%.
The last time I got a power-up it did not charge at all. 100% is preferable to not charging. Just wondering why Ford cannot get this right.
kwlinder
Northern VA
2022 Mustang Mach-E GT
I had the same thing happen to me the other day when I got the update. Also turned off 1PD which was a nice surprise when I put it in reverse and it took off.
This was a June 22 build, after the HVBJB fix.
Check your preferred charge settings in the car, PowerUps gave a habit of deleting them. Another possibility is that it messed with the GPS, that could cause the car to think it’s on a new charger and charge too 100%. Try rebooting sync to resolve a HOA issue. Hold down the next track and volume down buttons simultaneously until the sync screen goes dark.
robbinbadams
Robbin
Houston TX
California Route 1
Electrical Engineer
Also this power up turned off one pedal driving. Seems like Ford could do updates without changing preferences.
Yes, they are working on fixing that problem.
Motomax
Max
VW GLI, 4Runner
Have the high beams always faded on/off before or is this new? I feel like I would have noticed this before… haha.
Mine do not fade. They turn on, they turn off. ?‍♂?
Strange. That update and several before then did not turn 1pd off on my car.
Motomax
Max
VW GLI, 4Runner
I noticed the same with one of the 3.5.x updates. I think it is new.
The things they work on instead of fixing issues ?.
On the other hand, paak seems to work much better to start the car but looks like walk away lock isn’t as consistant anymore.
OON7
Evan
New: 24 GT w/ perf. upgrade Vapor Blue // Old: 22 GTPE DMG // 21 Select CG
On my 21 Select they were on/off instantly. On my 22 GTPE they have always faded on/off when using auto.
