- Jul 1, 2021
- SE MI
- 2022 Mach-E Premium 4X, 2022 Lightning Lariat ER
The car being ready to go is simply a warm cabin. The only way to precondition the battery, which gives you more range (and power) on the first leg of a trip, is to use a 30amp or higher charger. So, with 16A, you're not warming the battery as much.OK, so how do you know if the battery is "preconditioned"? I'm charging at 16A, with set departure times, everything seems to be working fine. Car is always warm & ready to go ar 6:50AM.
As has been posted many times, this impacts you if you're charging to 100% for a trip and want to maximize your range. The warmer the battery, the more range you get.
It also can impact your power, i.e. the amount of energy you can get at any time from the battery. If the battery is too cold, the energy will be limited until it warms up. You can't see that unless you have a GT/GTPE and see the "jail bars".
So, to sum it up, if you're doing a local 20 or 30 mile drive, you're just fine. But, if you want to take a trip and go as far as possible before stopping to charge (or simply want more power right away), then you need to up your charging game.
Some people believe that charging at a lower amperage will make the battery "last longer". In reality, if you're AC charging, the amperage (up to 48amps for the Mach-E) is really not an issue.
