- Lee
- Jul 16, 2021
- Wisconsin
- 2022 Mach-E Premium AWD
- Sci/Eng
Battery temp. A warm battery produces more kWh of energy than a cold battery, so you can go further. You're focused on heater usage, the battery temp is a big factor too.I must be missing something big in the equation. Just doesn't seem like it would add up to close to that difference for the entire drive. Early in the drive, yes.
Yes, I would precondition to the DC charger in that scenario, it will probably cool the battery off to 95F so you don't get a thermal derate.If your on a long road trip kind of day and the battery hits 113 deg F, and you use Ford Nav to go to the next charger, will it then cool the battery to get to 77 - 95 deg, or is 113 ok to get a 125kw charging rate? This assumes your in the 20% SOC range.
