Rear Tailgate Lift Not Fully Opening
Warp Asylum
Austin, TX
2023 Mach-E GTPE
i wonder if this is ford's fix to the mystery trunk opening issue.
my new 2023 premium is consistent in the following:
  • locked, no key present: trunk locked, no trunk opening on rear button press
  • locked, key present: trunk opens ~3" on rear button press
  • unlocked, key present: trunk opens fully on rear button press (driver's door open or closed)
  • locked, key present: trunk opens fully on 2x remote trunk button press
The above is the exact behavior my 23 has, and I'll add these:
  • Locked or unlocked, PaaK connected: trunk opens fully using the button in FordPass.
  • In Valet mode, any key fob/PaaK state: trunk will not open at all until Valet mode is turned off, which I just found out on a trip over the weekend. I believe this is expected/correct behavior that I was just not aware of.
smd95
Scott
Pennsylvania
Mustang GT
I'm glad you all posted this and forces me to check. The above comments are accurate and boiled down it seems like:
If the car is locked the trunk only opens a few inches when you push the button. With key or Paak. Second pick opens it fully.
If the car is unlocked it extends fully.
Space_Pony
Indiana
2023 Premium Mach-E awdX
It's my understanding that an update is rolling out to fix the liftgate. I haven't received it yet but a few have that it fixed it.
Deleted member 20140
Guest
I've had that issue since I got the car. Haven't correlated it yet with locked/unlocked or door ajar. I have had 6.13 for about a week. No difference.
WillTriumph
Boston
Mach-E GT AWD
It may be imagined, but I noticed a quick press opens fully. A longer press seems to open fully. Still wonky if true as most will push longer to open. YMMV.
Space_Pony
Indiana
I assume you have a 23 model. If so, if the car is locked the liftgate will stop after raising about 4 inches. If it is unlocked it will work properly. This only affects 23 models.
WillTriumph
Boston
Mach-E GT AWD
Yes, 23. A press again opens fully so baffled...
Regardless, appreciate the confirmation.
TowPro
Will
Central FL
23 F150, 23 MME
ours also does this, if locked it only opens a couple inches.
I read in Gethub the following powerup is coming.
hopefully this is a fix.
I am still getting November updates. Just got 6.3.0 I think
Mustang Mach-E23-PU0630-RGT-PLODecember 2023Not availableUpdates Have Been Made
We have made some adjustments to your liftgate to optimize its performance.
zvez
chris
ga
My FDRS report on my 23, I have the same liftgate issue. It's listed as "rear trunk gate (RGTM) module update" but according to this it involves a dealer visit?
Ford Mustang Mach-E Rear Tailgate Lift Not Fully Opening FDRS for 23 gt
Kelowna, BC Canada
Graphic Design
Can't wait as my 21 had no issues my 23 P Ex. does.. you hit the button get ready to load or unload and it stalls.. throws you off.. 23-PU0630-RGT-PLO Noted and will see if my dealer knows anything about this Super Thanks!
doitda
Diamondhead, MS
2023 Mach-E Premium EAWD
Yep same issue here on a '23 Premium Ex-AWD
