Recommendation for replacement tires
Silver Pony
Eric
Hyde Park NY
2021 premium mach e with extended battery and AWD
Geologist
I have a 2021 Mach e premium all wheel drive with 38,000 miles on it. The Michelin Primacy tires that came with the car are at end of their life. I was happy with the handing of the OEM tires and 38,000 seems pretty good for tire wear. I am considering Goodyear electric drive GTs as a replacement. I have also heard good things about the Continental pro contact RX tires.
Any feed back on these or other replacement tires would be appreciated.
Silver Pony
I put the Hankook’s on my car at tire replacement time. They’re marginally quieter, no real loss of range. I’m quite happy with them.
TRP
Mach E P4x, Ford F150
I'm sticking with the OEM. Got 50k out of the first set and am creeping up on 50k from the second set.
21 Premium ER AWD, I do not drive or corner aggressively, so YMMV
dcheng
Star White CA Route 1
Check out my post here: https://www.macheforum.com/site/threads/oem-tires-nearing-replacement-suggestions.32534/post-889604
I just replaced my factory tires for my 2023 Cali Route 1.
How is the ride for you? I have a 2022 RWD CA Route 1 with just over 22k miles. Tread is down to 5/32 on one pair, and 4/32 on the other pair. I have the OEM Michelin Primacy A/S, and I am somewhat disappointed with needing to replace soon.
Any change in range that you have noticed in your first day or two? :)
It seems that CC2 is a fairly popular option, but I'm a little concerned about the potential loss in range. I'm a fairly conservative driver (which is one reason I'm wishing that I didn't have to think about tire replacements so soon). I have appreciated getting over 300 miles and not needing to stop on the longer trips, so I'm hoping to maintain that capability.
LanceL218
Lance
Charlotte, NC
www.ldlnet.net
2023 Mustang Mach E California Route 1 Edition
i haven’t driven on them enough yet to notice as change in the range, but I B will let you know. The ride for me is more important at this point. The tread wear was about the same mileage as what you stated. I hope these go a little longer. I would think the range is very very minimal. Under 5 miles difference maybe. I would see if I could find some more reviews. I wasn’t concerned about the difference in battery mileage when I shopped.
dcheng
Thanks!
I think I've been reading so many different threads, and I know some people have gotten much more life out of the Primacy; I must have confused one of those with your post. I think I'm starting to approach information saturation.
I am encouraged with regards to the ride since you did mention that you noticed a ride difference. Does that mean it was quieter, less bumpy, better something else?
lifebythemile
Metro Vancouver
2023 Mach E Select RWD - Vapor Blue
I put CC2's on my RWD MME after about 8000km on the OEM's. The install coincided with our seasonal drop in temperature so take this with a grain of salt. What I did notice with my efficiency tracking is that I had about a 40% drop in range when temps went below 54F (within the same week as getting the CC2's installed), however after about 2500km my efficiency went up by about 10% even as the temps dropped down into the low 40's high 30's. I am guessing that is after the tires were 'broken in' and the rolling resistance wasn't as bad once the top layer was scrubbed off.
So based on that I would say to expect a 5-7% hit in range with the CC2's but for me the comfort and grip was worth the trade off.
