tomtel
Hi,
I currently own a Mach‑E 2025 Rally with a heat pump and I’ve run into a strange issue.
Remote climate control only works for about 30 minutes after turning the car off. After that, it won’t start anymore.
The second problem is that there is no cooling – everything seems to work fine, there are no error messages, the system runs, but it doesn’t actually cool.
Has anyone experienced similar issues or have any idea what could be causing this and what I should check?
