- Greg
- Apr 20, 2020
- Phoenix
- 2021 Mach-E FE, 2021 Wrangler 4xe High Altitude
- Manager
As already mentioned.....the owner's manual hasn't been released yet so we aren't sure. If it's anything like my Focus Electric then maintenance will be minimal. Once a year (or every 10k miles) Ford asks you to rotate the tires and perform a multi point inspection. Basic stuff....look for leaks, torn boots, loose brackets, brake pads, check tire sealant expiration date in the temporary mobility kit, etc.Newbie to the electric car world. Does anyone know what/if there is any scheduled maintenance for the Mach-E?
In the Other Maintenance table, it shows to replace the cabin air filter every 20k miles and change the coolant at 10 years or 150k miles (then every 5 yr/50k miles after that).
There is also a note somewhere in the manual to replace the batteries in your key fob at least every 5 years I think....
Other than that, not much to do except drive the thing and keep it clean.
