Set up PAAK
Stu H
Stu
Vacaville
2021 Mach E GT Pe; 68 Corvette, others....
New app for Ford pass just installed. Trying to set up phone as a key (PAAK)
Says that it has limited stuff for doing set up for Android device. . PAAK instruction keep leading me around in a circle. I'm getting dizzy.
Any suggestions other than stop going around on circles?
Thanks.
tomthetenacious
MachE
Hi Stu,
Can you post some screenshots of what you are seeing? Did you previously have PaaK installed or is the first time you attempted to set it up?
Thanks.
partial/failed configuration of PAAK can be a real PIA.... basically you have to remove everything from both your phone and vehicle, and start over as if you just took delivery.
https://www.macheforum.com/site/thr...on-android-to-enable-a-backup-startcode.4544/
Stu H
Stu
Vacaville
Ugh
Stu H
Stu
Vacaville
Everything?
Or just on the PAAK stuff?
Stu H
Stu
Vacaville
Hi Stu,
Ford Mustang Mach-E Set up PAAK Screenshot_20240125_082300_FordPass
Ford Mustang Mach-E Set up PAAK Screenshot_20240125_082322_FordPass
Ford Mustang Mach-E Set up PAAK Screenshot_20240125_082425_Device care (1)
Two Trick Ponies
Jack
Nebraska
1964 1/2 Mustang, 2023 Nite Pony Mach E
Set it up inside the car and have the master remote with you. Make sure your bluetooth is on and never turn it off if you use your PAAK continuously.
tomthetenacious
MachE
Hi Stu,
Can you clear the FordPass app data and try again? It looks like the application is crashing at the beginning of setup.
Stu H
Stu
Vacaville
Sure.
Stu H
Stu
Vacaville
Hi Stu,
Same result. I wonder of has anything to do with how close I am to the car?
I'm inside and car is in garage about 40-50 feet away....
Stu H
Stu
Vacaville
Oddly enough. It seems to work on the car anyway. Locks and unlocks, horn and lights do what they are supposed to do, and I think the car start stop work also. But I have yet to verify ad I have not gone out to the garage.
The app shows everything works properly.
Maybe the app thought it was wrong, but it was wrong....
tomthetenacious
MachE
Do you see commands like windows down / windows up? You can still operate some commands without PaaK. Commands like remote start, lock, unlock will work over cellular modem if PaaK is not configured. But window controls only execute over PaaK's bluetooth connection.
All the features you listed are non-PaaK. PaaK is windows up and down, frunk and trunk open, and using as a key.
Deleted member 19354
Guest
Thanks.
I’ve been getting the same and the help desk at Ford is useless. I had to have the dealer check out something finds out it was a module that went back and has to be replaced (under warranty). They also reassured me the module will not affect drive or safety.
