Setting address for Home.
Major
Major
Houston
Mustang Grabber Blue First Edition
This is probably obvious somewhere, but I haven't found it. I parked my car in my driveway and labeled that point as "home." Whenever I attempt to set my destination to home it says home does not have an address. How do I give "Home" an address?
Carsinmyblood
Mitch
Western NC
Self employed
Magnum Sharpie in big fat bold letters so it won't forget and will learn it's lesson.
Dry-erase if you're close to moving, of course.
I'll get my coat.
sockmeister
Pennsylvania
2023 Mach-E GTPE
SW Engineer
I don't believe that's how you save the address as home; that's probably how you set a Home "Charging location". You need to clear your set "Home" location in the map settings, and then type in the address manually. I had a similar problem until I did that. ("Home" was actually set as the plant in Mexico for me, so every time I went to navigate Home, it said it was unable to calculate a route...).
jdsimard2012
Joseph
Montreal
Mach-E
How was the trip to Mexio? lol
SpacePony
Kansas City Metro
2021 Mach-e Preimum AWD Ext. Battery
Go to navigation, press the “Where to” in the upper left, then to the “saved” tab, and delete the location you named “Home.” Now exit and go back to where to, and press the big “Home” square button on the first screen, and it will prompt you for your address.
