dermot
- Derek
- Jul 24, 2024
- Ontario, Canada
- 2023 Mustang Mach e Premium ER AWD, 2024 F-150 Lightning Platinum
- IT Leader
Ok so it worked, but not exactly as expected.23-PU1024-MCP-FX last night. Same issue, no location, charge time or target for home. Tried ford charger vs my Grizzl-e, no luck. 12v Battery pulled, timer on for 10min.
I’ll type things up better when I’m on my laptop however, this is what went down.
My home charging location was missing, presumably after the update last night. Anytime I plugged in at home. The vehicle started to charge immediately as there was no charge time settings for my home location. It also charged 100% because there was no target charge saved.
after I did the 10 minute 12 V battery trick, there were still no locations. I plugged in the charger and after a few minutes, a new location appeared. When I went to name at home, Home was already taken and greyed out in the list. So I used location one for now. everything was able to be set up with a charge and time window, etc.
So far I’ve not been able to find or delete my original home location.
