Sloshing Sound
BigMach-E
Bay Area
Mach-E GTPE Shadow Black 2021
Hi all,
I haven't seen much mention of this. But has anyone noticed a pronounced sloshing noise that is very intermittent? I think my car makes it most often during changes of the parameters of the climate controls, it sounds like liquid being moved quickly just about under the dash. This isn't really an issue, it just seems odd. I want to know if it's normal. The car is so quiet compared to may other cars, and it's such an odd noise is maybe why I notice it.
Jonno21
Derby, UK
Mach-E AWD Long Range Space White
Mine does it as well. Probably the pumps allocating cooling fluid between batteries/cabin/electric motor(s) depending on climate control settings. You wouldn't normally hear this on a fossil car as they're noisy anyway. :)
I have noticed it when starting the car, and I hear it better outside the car. Probably what you are hearing is normal, and like you said, easier to hear because there is no engine noise. Also, the battery coolant lines are big and probably make more noise than those on an ICE car.
smhenn
Steven
Des Moines
Mach-E Premium
Heard this sound for the first time yesterday. Glad it's nothing to worry about!
breeves002
Sam
St. Louis, MO
2021 Mach-E GT PE
It's the water pump for the heater. Anytime e heat turns on you'll hear the water. It's how I know it's turned on a lot of times. If the radio is on you can't hear it though.
Moigno
CA
Mustang
I’ve been hearing sloshing sounds when braking and accelerating. It’s remarkable to hear that others have been hearing these too, since I thought it was just me, for the following reason: After having the glass roof recall done some months back, the work had to be redone because of water ingress into the plastic panel above the rear view mirror. I thought the sloshing was because some water remained trapped in the bodywork… but after seeing this thread, I’m thinking maybe it’s just liquid circulating as designed?
Does anyone have opinions on where the sloshing sounds seem to come from? I could have sworn they were overhead but maybe I’m just imagining things. Is anyone else hearing them specifically when accelerating or braking?
BigMach-E
Bay Area
@Moigno yeah, I really think it's design. You don't notice them unless you are listening for them. This car makes all kinds of sounds that aren't typical for a car because you don't have the sound of an engine covering them up.
DrSteveBrule
MN
n/a
I hear it when starting up. I actually find it strangely reassuring in an "everything's working" sort of way. It's like the car is alive and ready to do my bidding.
I think you are correct and you are hearing the normal circulation of the coolant that is used to maintain the battery temperature.
Isn't this forum great! Now you can stop worrying about the sloshing sound! It is completely normal.
Lynsey
San Diego, CA
2022 Mustang Mach E GT - Star White
Love this forum. I never noticed the noise before. I first heard it today when starting the car, and was worried. Just searched "water sound" and now I can sleep ;)
