Slow Charging With Supplied Charger
Pina
Canada
Honda Passport, 2022 Mach-E Premium Ordered
Good Evening All
Has anyone noticed exceptionally slow charging with the supplied charger on a 240 outlet? Lately I have noticed that charging takes forever at home and now with the app update I can see it’s only pulling a charge rate of 3kw?
Thoughts?
Ford Mustang Mach-E Slow Charging With Supplied Charger 5E4AA6CB-E573-440A-AD37-3FA4B4CCBA3E
The Ford Mobile Charger (FMC) is known to have thermal issues, especially at 220-240V. Every time it gets used and it brings itself to a temperature that it can't really handle, it damages itself a little, resulting in slower and slower charging until it eventually just errors out. You would be doing yourself a favor by getting an L2 charger from a reputable manufacturer. ??
Pina
Canada
Thank you! Was hoping to avoid that but may be out of luck. I’ve had it for a year now with no issues.
Yup, junk charger only putting out 3 kW instead of 8 kW...
MacheTX RT1
Houston
Mach E 2022 California RT1
Same issues like yours after 6 months. I now bought a Tesla wall connector as i also have a model Y and a lectron 48 amp J1772 adapter and now my Mach E is pulling up to 10KW!
Jppumper
Largo, Florida
1st car: 1966 Mustang, 2021 Mach-E X Premium
Retired Master Certified Heavy Truck Technician
Good Evening All
Thoughts?
It's a POS. I bought a North American made Grizzl E charger and my charging problems went away.
DevSecNetOps, General PITA
Ditto but I got the j1772 version. The wall connector tells me 11.1 but I figure that 1 is the overhead. Sadly i thought it was going to be a touch more customizable than it is but it works and I really like that cord and it's size.
MacheTX RT1
Houston
Cool, the Mach E can accept 10.9 KW , I thought about the J1772 version but as I have the model Y went for that version. Compared to MY at 10KW Mach E pulls about 35 miles per hour compared to 44 for the Tesla.
MellowJohnny
Christian
YYZ
Solution Architect
Same started happening to me last month after circa 6 months. Replaced it with a ChargePoint Flex.
BTW - has anyone had any luck with Ford warranting it? I'd still like a "working" unit for traveling.
Kismit
Julie
Temecula, CA
22 MME Premium ER RWD IBSM ordered 11/6
Teacher
Mine is suddenly slower than if I had plugged into a standard 110 ;-( I'd really like to not have to replace it myself - is it not under warranty?
Mine usually puts out 6-7kW.
Izzle
Seattle
2022 Mus Mach-E GT Performance; 2008 Mustang GT/CS
I'm having an issue today where I plug it in to a 50amp outlet and it's only charging at 1kw... I tried unplugging and plugging it back into the car, the outlet, and the 50amp cord end and still will only charge at 1kw.
Anyone else had this issue of just 1kw? Based on prior comments it appears my charger may be defective.
I usually use it on 120v but was trying to charge it at a the neighbor's house with a 50 amp outlet in preparation for a long drive this evening.
Ford Mustang Mach-E Slow Charging With Supplied Charger Screenshot_2023-12-29-12-24-07-83_f85a9dcae275ee1e0920d804e6924647
