markboris
- Mark
- Nov 13, 2019
- Sonora, CA
- Currently: '20 Shelby GT500 FPB '24 Mach-E GTP GGM
- Retired
For anyone wanting to soften the suspension as much as possible on this car, two things need to be done. One, change out the springs with Ford's OEM Rally springs like I mentioned above and two, change out the tires with ones that have a higher load rating/grand touring category as Brian mentioned above.
Ford's OEM Rally springs have a softer spring rate and are taller giving the car more suspension travel. Both of these things will give a softer ride. Some might not want their cars lifted an inch taller but it will definitely help with the ride. OEM Rally springs can be had for $300 including shipping. Installation can be anywhere from $500 and up. An alignment will be required which will be around $125. Also adjustable camber bolts are needed to get the front camber back in spec. Those run around $30. Total to have the springs replaced with alignment can be had for as little as $955
Replacing the tires can cost a bit more than having the springs done depending on the tires purchased but definitely worth doing to further soften the ride. Brian mentioned if you have 19" wheels, size up to 245/50/19 105XL. You can run these tires at a lower pressure (37 psi) and choosing from the grand touring category, will help with the ride. Looking at two popular tires in that size/catagory, Vredestein Quatrac Pro+ are about $1070 for the set, Michelin CrossClimate2's are $1185 for the set. For 20" wheels, 255/45/20 105XL tires in the grand touring category, three popular ones are Vredestein Quatrac Pro+ are about $1040 for the set, Michelin CrossClimate2's are $1270 for the set, Michelin Primacy Tour A/S $1310 for the set. Depending on the tire dealer, install may be free or not. Bottom line, probably looking at at least $1100 or more to change out the tires.
All that said, you would be spending around $2200 or more to do the best you can to soften the ride and it definitely will.
EDIT: As Steve mentions in a post further on, both of these things will slightly reduce your range. Raising the vehicle and running lower tire pressure.
