Solved: What are these!?
MachEMaster
Will
Canada
1997 GMC Yukon GT
Aircraft Maintenance Engineer
I was vacuuming under the rear cargo compartment floor. I found these two loose plastic parts. Does anyone know what their purpose is? Thanks.
Ford Mustang Mach-E Solved: What are these!? IMG_2331
Those are the safeties for the explosive pack. It is now armed.
Never seen those before.
Schmedlack
Dundalk, MD
2014 Ford Escape S 1925 Ford Tudor (2-door)
Trader
Look hard or use magnafication to see it these have a part number. If they do, try looking up the number as a Ford part.
JohnFoxeSheets
San Francisco
johnfoxesheets.com
I’m pretty sure those hold the HVBJB contractors closed. They must have sprung loose, right through the floorboards… ?
Gil McC
Gil
Beaverton, Or.
2012 Shelby GT500, 20Infinity G37X, 2021 MME GT PE
I have never used it but what does the end caps of the cargo cover look like?
Yes looks like the holders I bought after-market to keep the cargo cover a bit more secure.
zvez
chris
ga
Do you have a pet? They look like the plastic wing nuts that hold my cat carrier together.
LOL was thinking the same thing!
MachEMaster
MachEMaster
Will
Canada
1997 GMC Yukon GT
I think you nailed it! I will check the kennel when I get home! Thanks.
AzYooper
Paul
Sun Lakes AZ
2023 Mustang Mach-E AWD Extended Range
Might be something used in delivery transit that the dealer forgot to remove.
