Speaker thud, static, noise problem
IndyMache
Peter
Indianapolis
Mustang Mach-e First Edition
Today, for the first time, I was surprised by random deep, base sounds (thuds) coming from my rear speakers when playing audio either from CarPlay or the built-in radio. At first, it sounded like someone was banging on the back of the car, but it was actually coming out of the rear speakers as a deep thud or thump. I also had occasional static. Oh, and the engine sound generation is NOT active.
It was random, but persistent, regardless the audio source, and definitely stopped when I turned off the audio system. And then it would start again randomly whatever the input source. Has anyone experienced this? I’m hoping there’s an easy fix so I don’t have to go back to the dealer, but I realize I might. Thanks so much for any guidance!
I can’t seem to find anything about this, but please point me in the right direction if I missed it. Thanks!
Neil4Real
I've had random audio wonkiness, just yesterday only my passenger side speakers were working. Try restarting the center screen - volume down, next track on the steering wheel held down together until you see the screen reboot, about 10 seconds.
Ford Motor Company
Official Ford Account
Hi Peter. Can you send us a DM with your VIN and dealership info? I can look into this for you.
A2Z
Arlington, Virginia
MME GTPE; MME Select AWD
I had exactly the same thing happen to me today. CarPlay was working well in the morning, but when I restarted my car after stopping to pick up some groceries, the rear speakers played a series of loud thuds. I tried to play music from a number of playlists, but the songs were barely audible and turning up the volume made only the thuds louder. I deleted my phone from my car and then added it back a few hours later and, once I did, everything was back to normal. I am not sure whether deleting and readding my phone did the trick or whether the issue resolved itself, but the problem has not reoccurred.
Caused by a low 12V battery. Drive the car around for several hours to charge the 12V battery back up, or use a 12V battery charger. If the thumping persists, then you should pull fuse #23 under the glove box to reset the audio amplifier.
