ToadStool
PNW
Ford Mach E GT
Lots of wheel and tire guys say you can't put 275's into a GTPE, at least on the front. But I did it! I used MRR FS06 20"x9" forged flow formed wheels, with (this is IMPORTANT!) a +35 mm offset, i.e., an ET35 setup. This gave me a finger's clearance on the inside edges of the wheel wells. Why not go with 295's on the rear? Because I'd need a wider wheel on the rears, which would disallow tire rotations (10" wouldn't fit on the front), and most importantly, GTPE's already understeer, so why would I add more? I bought the new adjustable Steeda anti-sway rear bar, to dial out the existing (pre-wheel/tire change) understeer (increases the rear anti-sway from 200 pounds to 250-300-350 pounds).
Why not use forged? I got two bids on fully-forged wheels, with one quoting $1500/wheel, and the other $1250/wheel. Neither would guarantee fit. The MRR's were $590 each, including free shipping! MRR also said that 275's wouldn't fit on a GTPE...which just means that they hadn't gotten word that it would work from an end-user. The forged wheels weighed about 23-24 pounds each...the 9" MRR's weighed 26.2 pounds (I weighed the MRR's myself on a digital scale). That compares to the stock GTPE 8" forged flow-formed wheels at 29.5 pounds.
MRR uses different procedures from other wheel manufacturers. They have the wheels built in Taiwan (like everybody else), but the wheels are shipped in an uncompleted state. The offset, bore, surface treatment and powdercoats haven't been done yet. MRR pre-orders many, MANY of these unfinished wheels, and stores them in Caliifornia. Then, when you order the wheel you want, you get to specify the bore, offset, surface finish and color yourself. They then finish making the wheel in California. Whereas the other two wheel companies specified a 4-6-WEEK wait for the wheels, MRR specified a 6-DAY wait! My wheels, which had an extra custom finish, involving extra labor (and cost), were ordered at 4:30 pm on a Friday, and delivered to me 8 days later, on the next Saturday, at 12:30 pm. Did I mention the shipping was free?
The wheels came with a 66.6 mm hub bore, and the Mach-E's have a 63.4 mm hub. My fault, I didn't specify the hub bore...I would specify a 63.7 mm bore if I did it again. I added 63.4 mm-to-66.6 mm hub ring adapters (plastic), so the lug bolts wouldn't be carrying all of the weight.
I worried about how hard it would be to force 275's onto 9" rims (the wheel specs for these tires say 9"-11" wheels are okay). So I coated the outsides of the wheels (1 coat), including the TOP OUTER EDGE, and the inner surfaces of the barrels (2 coats) with Gyeon Rim Q2 ceramic coat. The Gyeon Rim ceramic is a special high-temp coating, made to withstand the high heat from brake calipers. So far, brake dust doesn't seem to stick. When I finished the coatings, the insides of the rims felt like glass. Note that this is a "Pro" coating ($50 on Amazon), but I had no problem applying it. NOTE: on YouTube, the guys showing you how to apply it are doing it wrong...they're applying it much too heavily (I had NO "high spots" when I did it). Just read (backside of the front label) the directions, and follow them, and watch the application video Gyeon has on their website. I had enough of the rim ceramic "vial" left to maybe do 1 additional coat on 2 more wheels.
My tire guy (Premier Mobile in W. Sacramento...find him on the Tire Rack site) said that he had no problems getting the tires on..."probably due to the ceramic coat". Note that I put NO ceramic on the inside edges of the wheel lips (where the tire rests against the rims).
Finally, I had to do a very slight mod to the inner rear felt fender liners. They hang loose from the inner wheel-well metal, and have about a .5" gap between the felt and the metal. I used a 6" piece of black gaffer tape to pull the felt back to the inner well's metal at one point. If you crank the front wheels to the extreme left or right, you can hear/feel a very slight rubbing on the felt liners, but only from a dead stop (like exiting a parallel parking space). I hear/feel no rubbing while cornering, fronts or rears. And no scraping on the front wheel well lips...no grinding necessary! Gaffer tape is like duct tape, but it's stronger and has a MUCH stronger adhesive. I hung some paintings temporarily on a set wall once, with small loops of gaffer tape, and it pulled the outer-and-middle surface of the drywall off. Sold at motion picture supply stores in Hollywood.
Results? My GTPE corners much harder before slipping. And the car feels MUCH more planted on the road (probably due to both the increase from 245 to 275 in width, and the decrease from 45% to 40% on the aspect ratio). General (owned by Continental, who also owns Hoosier) G-Max RS's came in third in Consumer Report's "High Performance Tire Tests", slightly behind Michelin Pilot Sport 4S's and Pirelli P Zeros. Their wet braking was better than either of the others.
I got the G-Max's for $196 each, when the Pirellis were $348 and the Pilot Sports were $379. AND the G-Max's have a wear rating of 350, which I feel that our heavy cars need. Tire noise is slightly more (5%), and the ride is slightly stiffer (5%). They have a 10.82" tread width. Range? I'm doing a mountain drive from Tahoe to Nevada this weekend, and will report back.
You really did well here. I'm amazed at how much difference a good wheel/tire combo does for the Mach E models. You've assembled a nice aggressive / fun look. The stripes really complete the package. In fact, although the cyber orange is a fabulous color, I did not think that color was very complimentary to the Mach E design. At least that's what every picture and video led me to believe. But what you've done here was make the cyber orange look very appealing.
I just wish Ford would have taken a few of these liberties for the GT and GTPE. They could have done so much more. Oh, well. Still a fabulous EV.
Still anxious to hear how your trip goes regarding potential tire rubbing, ext. Thanks.
RetiredDP
RetiredDP
Camino, CA
Focus RS
No tire rub, period. I took one corner in the mountains, going downhill at the time, that was labeled as "30 mph". I took it at 62 mph, and got just a tiny amount of tire scrub on the fronts. Gradually accelerating took the tire sob away. All noises were from tire slippage...NO tire rub on any body panels. Note to readers: DON'T try this yourself...I have many years of race experience.
Ford Mustang Mach-E Stuffing 275's into a GTPE (square setup) Studio_20170819_181833
RetiredDP
RetiredDP
Camino, CA
Focus RS
I’m curious about the results you obtain once you track the G-Maxs in the 5000lb GTPE. I’ve never run them on track but I’ve run Pilot SS, Conti ExtremeContact Sports and Goodyear F1 Supercar G2s in the last 10 years and they have all held up rather well as far as treadwear and resistance to heat-induced greasiness goes.
I know you site the CR report but the Tire Rack track testing seems to put them a ways back from the max performance summer category leaders in outright track numbers. Still, at $190/each perhaps that’s worth it over $300 Contis and $375 Pilot 4S’.
Also, good to see another square set up believer, I did 275s square on my OEM 245/275 SS Sedan in order to mitigate a very slight entry understeer condition and it worked great. Also looks better and improved threshold braking a bit to boot.
Remember, it's a near-5,000 pound car. I doubt that 180-treadwear tires (Cup-2's) will hold up during autocrosses with a near-5,000 pound car. I only got 13k out of mine with a MUCH lighter Focus RS. I got 16k out of my Bridgestone RE-71R's, but again, that's a much lighter car than a Mach-E GTPE. That's why I like the G-Max RS's...a 350 wear rating should hold up better. No, they won't last 35k on a GTPE...but they WILL last longer.
RetiredDP
RetiredDP
Camino, CA
Focus RS
I just entered my Mach-E into a Mustang Club of America national competition. MCA's President Steve Prewitt said that I was the first Mach-E EVER entered into ANY MCA national competition (not display-only). About 300 Mustangs were in the event. Result was the President's Choice Gold Award. An article about this car should appear in the August 2022 "Mustang Times".
Ford Mustang Mach-E Stuffing 275's into a GTPE (square setup) 20220522_211504
My first electric (literally) trophy!
Zer0t
Rumson, NJ; Marco Island, FL; Amelia Island, FL
2023 Model S Plaid
It makes me so happy to see the culture of car mods doesn’t die with EVs.
Looks great and nice write up. How’s the ride quality with the new setup?
I just entered my Mach-E into a Mustang Club of America national competition. MCA's President Steve Pruit said that I was the first Mach-E EVER entered into ANY MCA national competition (not display-only). About 300 Mustangs were in the event. Result was the President's Choice Gold Award.
That’s a freakin awesome trophy!
You had to be a little shocked to win that though. Have you done more mods than just wheels and vinyl?
RetiredDP
RetiredDP
Camino, CA
Focus RS
Wheels with an unusual finish, Steeda antisway bar, Schroth racing harness, racing numbers, felt liners in center console, "different-from-stock" stripes, decal license plate, PPF, self-applied ceramic coat, and owner-applied high-temp ceramic coating on the rims. All the other cars in the "President's Choice" category were mostly unmodified-by-owner factory-modded specials from Ford. Amazingly, the MCA president said that "Your car is the ONLY Mach-E ever entered into competition (not display-only) at ANY of our national events".
RetiredDP
RetiredDP
Camino, CA
Focus RS
5%-8% firmer. MUCH more "planted" feel. Range dropped from 254-256 to 250.
Oh that makes more sense. I’m not familiar with the categories. Was picturing a bunch of highly modified classics in national competition. It’s fun to win!
I like that the electric car won the electric trophy too!
RetiredDP
RetiredDP
Camino, CA
Focus RS
You will take a bigger range hit with aftermarket wheels due to aerodynamics than you will with the wider tires. ??
Aerodynamics may not take much of a hit, due to the air curtain formed over the front wheels by the air intake/exit slots on the front and back of the GT's front fenders.
Aerodynamics may not take much of a hit, due to the air curtain formed over the front wheels by the air intake slots on the GT's front fenders.
As someone who has just a tiny bit of aeronautic education and has not seen the aero data, I remain unconvinced. Hoping against myself that this is the case, though. ?‍♂?
nashbrydges
Sylvain
ON, Canada
2022 Mustang Mach-E GT performance
Looks good, I went with MRR last year on my GT as well. If thinking about mud flaps, they look pretty good and help keep dirt and chips off. Here is mine. Just wish I had painted gloss black first.
Did you get the mud flaps from the dealer or straight-up Amazon buy? I'm considering adding those to mine.
fallguy
fallguy
The south
2020 Defender, 1968 Mustang, 2021 Mach-E GT
Federal
Jimmy2
Jimmy
Wilmington NC
You guys on here tracking your 5000 lb MMEs amaze me; my hats off to you.
RetiredDP
RetiredDP
Camino, CA
Focus RS
They wouldn't have put the air curtain slots into the GTPE's fenders for no reason. It's to reduce drag from the wider wheels-and-tires on the GTPEs.
