Superstalk gear shift !
johnnycombo
Pennsylvania
Ahlarict
B.L.M.
Greater Cascadian Megalopolis
2024.5 60th Anniversary MME Rally Edition - "Shadowfax"
International Man of Mystery
When I read ”Superstalk gear shift”, I thought where can I get one! But then I read the article. If we put our collective heads together we can give it a better name. I’ll start, cluster shifter, cluster function , cluster fu…… I’m out of ideas. https://fordauthority.com/2025/04/2...t-pump-superstalk-gear-shift/#google_vignette
Marketers gonna market. They kinda fell down on the job with the "40% smaller frunk", tho - They should've come up with something like "lightweight performance frunk improves steering feel through 40% weight reduction!"
johnnycombo
johnnycombo
Pennsylvania
Yes, their motto is, we strive to make you feel good about something you’re really not going to like!
I've got a restraining order on the superstalker and on micro-frunk. ??
2026 Velocity Blue GT/CS
3-on-the-tree. The tech has been around since at least the 50s. A giant leap backward for Ford (not to mention a horrific User Experience downgrade).
phil
LS400
Horrific? Why does a column shifter bother you? I always liked them ok. Even without a "superstalk"!
GreaseMonkey
Chicago, IL
24 Mach-E GT
Is Donna talking about us when she says “built strong relationship with our customers”?
While I am not a fan of column mounted shifters, I also really do not like the rotary shifter. The superstalker is more or less a side-grade to me. I want an actual linear stick shifter that locks out Reverse when in Drive and Park when in Reverse. A simple button at the top of the knob can override the lockout but not allow the override to shift straight from Drive/Neutral into Park. This is tech that’s been around since the ‘60s, so it’s not like it’s that hard to implement. ??
load97
No3ne
Since getting a 2015 Ram 1500 with a rotary shifter, I’ve become a fan of the rotary dial. Especially when it’s position is where my hand rests naturally.
It’s an antiquated interface that occupies a lot of volume in the user space and is not very intuitive.
Ahlarict
B.L.M.
Yet they left the parking button there taking up a third of that "valuable real estate"?
E90alex
Seattle, WA
‘25 MME GT
The monostable column shifter works great, assuming it works like Tesla (who stole it from Mercedes). Especially for going quickly between D and R like a 3 point turn or parking. Don’t need to look or feel or count clicks of a dial. Don’t need to take your hands off the wheel. Just stick a finger out while holding the wheel and push it all the way up for R or down for D.
I don’t understand how one could say it’s taking up more space when it freed up extra storage space in the center console.
Jack Roberts
Atlanta
Mach e GT
