SVS - Powertrain Malfunction - No Codes?
MachyMark
CA
Mach-e Select AWD
I received a SVS light in the car and a Powertrain Malfunction / Reduced Power Fault in the app. The car is driving just fine, no issues with the AWD system and experiencing no reduced power. I did not get a Stop Safely Now message
I have tried 3 different OB2 scanners and none have been able to pull a code. Is there a specific scanner I should be using for this car?
Dealer is booked out 1 month, so trying to identify the issue to make sure we can still drive on it.
Thanks!
mikes pony
Gwynedd
Mach E ER AWD
Heating engineer
Same problem here, it is a little worrying
Randall
Randall
Denver CO
Mach E
Call the Ford dealer service dpartment with the vin or your phone number if you've been there before and ask them to 'pretty please' pull the codes the car has sent. They should be able to tell you if it's safe to drive.
Thanks!
The scanner needs to support Ford-specific parameters, a generic OBD reader will not work on EVs since they are not required to support OBD.
FORScan, Torque, and Car Scanner are examples of apps that support Ford-specific parameters.
MachyMark
CA
Mach-e Select AWD
Dealer helped, kinda! They said there are too many codes to list out. Lot of module errors and Power train controls module error
GrayWolf
Brent
Atlanta, GA area
2021 Mach-E GT (Star White Metallic)
Interesting that my car just pulled the same thing on me today.
@MachyMark did you happen to find out what happened to your car?
GrayWolf
Brent
Atlanta, GA area
Gotcha - hope they can get it figured out quickly for you. Thanks for the quick response!
GrayWolf
Brent
Atlanta, GA area
I’ll let ya know what they say!
As a 'Fun" update for my situation - the car seems to have realized that its error code was, itself, a mistake. The SVS is gone and no further alerts have popped for me. Gotta love a "haunted" car. :D
MachyMark
CA
Mach-e Select AWD
Turns out mine was the charge port door. Dunno how it’s connected to powertrain but that’s what the dealer diagnosed it as
Grandpa Gus's pouches can temporarily discourage the things. You need to replace them regularly, and they can get used to the smell and decide to ignore it.
